What characteristics or traits should a speaker have that is intended for use with a vacuum tube amp.
I realize high sensitivity is required and I think constant ('flat') impedance as well. What besides these two things what else should be taken into consideration for building a speaker for VT amps ? Thanks! |
#2 |
There are no real requirements. Use the loudspeaker you like best, just so it is reasonably well behaved. High sensitivity is only needed if you are using a low powered amplifier.
#3 |
Many speakers work well with tube amps especially "full range" driver systems. You may find this article informative.
http://www.6moons.com/audioreviews/f...firstwatt.html |
| Varying 2 tube amp characteristics: SE treble and richness | otto88 | Tubes / Valves | 5 | 14th October 2008 12:54 PM |
| Variability of RIAA eq with tube characteristics? | leadbelly | Tubes / Valves | 21 | 15th April 2008 06:29 PM |
| Tube Characteristics | fauxpas | Tubes / Valves | 0 | 24th November 2007 08:27 AM |
| Tube amp design characteristics? | NewVintageNut | Tubes / Valves | 20 | 30th May 2004 09:07 PM |
| Matching Speaker Characteristics | squidbait | Multi-Way | 3 | 9th January 2004 07:31 AM |
| Page generated in 0.07529 seconds (76.65% PHP - 23.35% MySQL) with 10 queries |
