Old 13th December 2004, 06:31 PM   #1
Default Diodes in passive crossover
My boss and I were looking at some crossover disigns from some very high end speaker cabinets, and noticed that there were diodes in the circuit. Can anyone tell me what the hell diodes are doing in a passive crossover? I have seen diodes in crossovers before and I cannot figure out why. And I have only seen them in very expensive speakers. Any insight or answers will help me sleep at night.
sean
Old 13th December 2004, 11:56 PM   #2
Quote Greg Weaver, from Soundstage! magazine:
The crossover is nothing more than a specialized filter, consisting of coils, capacitors, resistors and diodes.
Well, Greg Weaver seems to feel they belong in passive crossovers as well. If you get no answers, consider Emailing him.
http://www.soundstage.com/synergize/synergize031998.htm
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 14th December 2004, 12:04 AM   #3
Those diodes you saw in the speaker crossovers. By any chance were there also electrolytic capacitors in that circuit?
I am wondering if the speaker manufacturers decided to take two polarized electrolytics and added diodes instead of using non polarized electrolytics, for high value capacitance.
My next guess is that since diodes have a logarithmic characteristic, the expensive speaker designers have some sort of circuit where a high slope is achieved by the diodes, and is by passed by other components to make up for the 0.6 volts requirement.
Just guessing.
-Anonymous
Old 14th December 2004, 08:11 PM   #4
Yes of course there are caps in the circuit, along with resistors and inductors, your idea of creating a steep slope may be correct, i think ribbon tweeeters were used (which require a fairly steep slope depending on the driver and crossover point). Good explanation... any others?
sean
Old 14th December 2004, 08:19 PM   #5
leadbelly's Avatar
Hard to have any insight without at least seeing the portion of the schematic with the diodes, can you post or describe it? Either protecting polarized caps as KW suggested or used as a high value resistor in reverse bias is all I can think of.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 14th December 2004, 09:36 PM   #6
ScottG is offline ScottG  United States
diodes are sometimes used in powersupply to reduce noise.
after thinking a bit more about it the term to search for on the web is "snubber".
perspective is everything
Old 14th December 2004, 09:56 PM   #7
Timn8ter's Avatar
I only find them in active crossovers.
Old 14th December 2004, 10:09 PM   #8
Bill Fitzpatrick's Avatar
Why do I think that a diode, unless an LED, in a crossover is ridiculous?
Old 14th December 2004, 10:12 PM   #9
tomi is offline tomi  Wales
Location: Aberystwyth and Manchester, depending upon term times.
Hi there guys.
It does indeed seem bizarre to put diodes in a crossover network. As preveous contributors have said, it's hard to know what they are supposed to be doing without seeing the exact configuration; Still, I can't see how adding the non-linear characteristics of a diode can possibly alter to the frequency response (to give a steeper roll-off).
My best guess is that they might be (hefty) zener diodes, in place to shunt the drivers or caps in case of overload... but even that's a long shot!
And for the record, I've never seen a filter, active or passive, with diodes in the signal path.
Cheers!
The Geek shall inherit the Earth.
Old 14th December 2004, 11:01 PM   #10
Timn8ter's Avatar
Yup, not in the signal path.
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Passive crossover Twisted Parts 0 19th January 2004 08:32 PM
About passive crossover stefanobilliani Pass Labs 5 2nd August 2002 07:39 PM
Page generated in 0.10935 seconds (70.38% PHP - 29.62% MySQL) with 10 queries
