Old 13th December 2004, 05:52 PM   #1
jmikes is offline jmikes  Canada
Default Crossover math check
I'm still getting a handle on reading schematics and doing the math required for crossovers and I have a question. I was looking at the Angelfire crossover on the PartsExpress project showcase page, and the builder states the tweeter is crossover at 5150. When my rusty brain clanked into gear and worked out the numbers, I got a answer more like 3200. Can someone take a look at it for me?
Thanks in advance.
Old 13th December 2004, 05:55 PM   #2
Speakerholic
Cal Weldon's Avatar
I'm no expert on Xovers but I was wondering why the take off for the tweeter is after the mid cap. Is this a common practice?
Cal
edit: The mid and tweet are only a 6 dB while the woof is 12? Is this also on purpose?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 13th December 2004, 08:49 PM   #3
Bill Fitzpatrick's Avatar
It is common practice but put the 28mfd (most certainly electrolytic) in the tweeter line which some would consider very bad.
Even if you consider the series combination of the 2 caps, the crossover freq. disparity is probably due to the fact that the tweeters unfiltered response is also considered.
Old 13th December 2004, 09:04 PM   #4
Not sure I understrand. Can you translate?
I'm lost again. The tweeter (Morel 37) shows good response well below both of the stated crossover points. Why should it perform so badly with that circuit?
Old 13th December 2004, 09:19 PM   #5
Speakerholic
Cal Weldon's Avatar
You will note the signal has to go through the 28 cap before going to the 7.7 for the tweeter. Bill mentioned it was a common practice. I'm not sure why, it doesn't seem to make sence on the surface.
Nor do I understand using a bypass resistor on the woofer.
Old 13th December 2004, 10:14 PM   #6
frugal-phile(tm)
planet10's Avatar
I've seen this quite often... nets you a 6 uF cap on the tweeters (and no doubt means that the 7 uF cap has to handle a lot less power.
If you are calculating a text-book XO using an 8R loas you have to realize that the real impedance of the tweeter actually has little resemblance to an 8R resistor so the text book formulas are at most an optimistic guideline.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th December 2004, 10:30 PM   #7
It's not a bypass resistor on the woofer, it's a zobel.
And now that I look at PEs project page I see that the 28mfd is a poly cap so that negates my comment about it being a bad idea.
So, I'd say that they did all that they did based on parts on hand and the need to do some response tailoring. The exact crossover freq. is often a nebulous number.
Can you check this crossover repair job? silentblackhat Solid State 0 10th November 2008 12:55 AM
Check my math? Jalex420 Chip Amps 18 3rd June 2006 08:58 AM
double check the math tenderland Tubes / Valves 3 27th March 2006 04:48 PM
check my crossover rv1890 Multi-Way 18 25th February 2006 09:35 AM
DIY Sub with DAYTON RSS315HF-4 in progress; Can someone check my math? bcycle Subwoofers 18 7th February 2006 10:30 PM
Page generated in 0.11329 seconds (70.88% PHP - 29.12% MySQL) with 11 queries
