Consider a bi-amplified 2-way loudspeaker.
One amplifier is connected in a balanced connection, resulting that it provides higher SPL values than the other amplifier, so the two options are: Opt. 1 - Use a tweeter of higher sensivity (like 95dB) and a woofer -3dB (91dB in the example). Opt. 2 - Introduce an -3dB attenuation circuit before the tweeter. Which one do you recommend? Regards, Thanks! |
#2 |
I always include some sort of level adjustment for the tweeter, since even if you match the nominal sensitivities of the drivers, there is no guarantee that they will actually match well at the crossover. Plus it then frees up your choice of drivers.
https://mrevil.asvachin.eu/ |
#3 |
Mr Evil
Fixed or variable level adjustment? If variable, of what kind? |
#4 |
Did it Himself
I usually just use a pot at the amp frontend, and my ears
#5 |
Usually a trim pot which I set once and then leave alone. With proper measurements then maybe fixed attenuation (or gain if you happen to have a less sensitive tweeter) would be better, but I prefer to have the flexibility to make adjustments so I can change drivers easily if needed.
| Equalizing + & - output voltage? | Sherman | Tubes / Valves | 3 | 2nd November 2007 06:56 PM |
| amplification needed???? | swaroopvg | Subwoofers | 1 | 4th July 2006 06:45 PM |
| amplification? | xstephanx | Full Range | 29 | 4th June 2006 05:58 PM |
| Equalizing input volume | jaudio | Chip Amps | 8 | 19th April 2005 10:33 PM |
| Amplification | Howard | Subwoofers | 5 | 25th December 2004 07:03 AM |
| Page generated in 0.07506 seconds (65.81% PHP - 34.19% MySQL) with 10 queries |
