Old 8th September 2005, 06:51 PM   #11
reins is offline reins  Germany
I have great expierence with usher 8137 as midrange. I use the peak at 3,5kHz to extend the drivers range to 4kHz. How is it done? I cross over at 2,5kHz 2nd order LR and cross the tweeter (ribbon) at 4k with 4th order LR.
This sounds great. The lower crossover is 160Hz. With the 8" Usher driver output capability is not an issue, beaming might be but I found no problems here by listening.
Stephan
Old 9th September 2005, 04:29 AM   #12
DougL is offline DougL  United States
interesting...so did you ever get past prototyping these? and if so, how'd they sound?
I am in the process of building them now.
I plan to have them finished by DIY Chicago Next month.
I changed the Midrange to a single SEAS MP 14 RCY/P for the final design. Now if I can get my measurement system running.
Got to love SoundEasy.
I am also taking the proto's to DIY Chicago.
It’s interesting what $50 in drivers can sound like.
Doug
Old 2nd December 2008, 04:56 PM   #13
bhuvana is offline bhuvana  United States
Default Re:Wide-band Dipole Project
I am having certain configurations in my mind and i will let you know after confirming its availability in the shop.
bhuvana
Link Building
Wide dispersion speakers using full (wide) range drivers ozziozzi Full Range 1 28th December 2008 06:13 AM
Best Tang Band for first time project? type Full Range 20 23rd March 2006 09:55 PM
Possible wide baffle project Scottmoose Full Range 6 25th September 2005 01:16 PM
Wide band Common mode chokes by Murata Dr.H Digital Source 2 3rd July 2003 03:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
