Old 12th December 2004, 07:27 PM   #1
robmonk is offline robmonk  United States
Question line-level crossover -- design help, please?
I want to build line-level crossovers so that I can bi-amp my two-way cabinets featuring VIFA 5-1/4" and seas soft-dome tweeters (I don't have my tools, so I can't look at the model numbers just now...). If anyone can point me to basic (tunable) circuit designs and help for calculating the resonance of different resistor/capacitor values, I'd love it.
I've been tinkering with crossover frequencies using a UREI electronic crossover (18db/octave active crossover with independent gain controls per output), and currently find that a crossover-point of 4500 Hz sounds best to me. I've set the hi/lo gain controls fairly similarly, so I'm hoping that I can get away with a fairly simple 'black box' circuit, or at the most, one with a simple hi-frequency attenuator, to match the hi/lo output levels to the drivers' different efficiencies.
I wonder what the consensus is on ideal crossover slope and other characteristics for line-level crossovers feeding a two-way system?
Is there such thing as a passive line-level crossover? Are there considerations of creating mismatch between preamp output inpedence and the amplifiers' input impedence, by inserting a passive circuit?
- Rob
Old 12th December 2004, 09:31 PM   #2
joensd is offline joensd  Germany
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
If you donīt mind opamps you could build Rod Elliots 12dB/24dB-Linkwitz-active XO; works great for me.
BTW: The forum has a search function
jens
help with passive line level crossover PLLXO for 33K impedance amps Daveis Analog Line Level 1 14th December 2008 08:12 PM
Simple Line level buffer/active crossover? gregorx Subwoofers 37 28th July 2008 04:56 PM
$30 Active Line-Level Crossover Nappylady Multi-Way 23 20th September 2005 06:53 PM
line-level crossover schematics? (WANTED) robmonk Parts 1 13th December 2004 07:31 AM
Passive line level crossover rulezzz Multi-Way 3 7th January 2004 08:45 AM
Page generated in 0.07391 seconds (68.19% PHP - 31.81% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
