Old 11th December 2004, 04:08 PM   #1
Default budget sub-sat system with tangband drivers
I want to build a cheap sub-sat system with a small sub for a friend of mine.
I was thinking about 5 small speakers using the W3-871S and a sub using the W5-876SA
My only concern is the power handling of those W3-871. It's only 20 watts. Will that be a problem for home theater? They will use it in a room of about 4x5m at modest levels.
Should I use a closed or vented box? Two drivers per box?
For the rear speakers I wanted to build something like those mission surround speakers (like the md5s). with two drivers, each facing another direction.
Any thoughts are welcome!
Old 11th December 2004, 06:20 PM   #2
This page (Zaph is a member here by the way) has a nice writeup on the 871 with several different cabinet variations, and some discussion on HT use. He has also designed a simple notch filter that apparently does quite a nice job at smoothing the speaker's response in any other those cabinets.
Budget T-amp system sub? wakibaki Subwoofers 21 3rd March 2008 02:30 PM
Budget system / Realistic Nova-10's truz05 Multi-Way 14 16th January 2007 11:04 PM
budget dorm system Evazan Multi-Way 10 22nd September 2006 05:18 AM
3-way around the TangBand W4-657SB: what drivers? tcpip Multi-Way 4 1st June 2006 07:07 AM
Budget for Surround System? CZ Eddie Multi-Way 4 23rd November 2003 10:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
