Old 10th December 2004, 04:07 PM   #1
Soulwax is offline Soulwax  United Kingdom
Default L-Pad Question
If I use a series L-pad before the LF coil to attenuate the output of a woofer (such that the L-Pad is wired externally between the bi-wire terminals of my loudspeakers) will the impedance of the L-Pad be summed with that of the coil and alter the LF crossover frequency in anyway?
Old 10th December 2004, 04:57 PM   #2
Bill Fitzpatrick's Avatar
Yes. If you have to have an L Pad on a woofer it should go after the coil and even then it will affect the crossover to some degree. Using a pad to reduce the input to a woofer is a bad idea anyway. You're likely to burn up the pad and it will change the Q of the woofer.
Old 11th December 2004, 10:07 PM   #3
Cheers Bill.
My speakers have an essentially dull balance and I’m looking to add a little more HF sparkle. Would removing the tweeter damping resistor (4.7ohm wired in series before the cap) be a better way to proceed? My speakers are rated at a nominal 8 ohms with minimum impedance around 4.5ohms.
Old 11th December 2004, 10:45 PM   #4
Yes, remove the tweeter resistor and increase the cap value by about 30%.
Old 12th December 2004, 05:31 AM   #5
morbo is offline morbo  Canada
I usually only see L-pads on tweeters. Is it possible and/or adivsable to use an L-pad on a widerange driver crossed to a woofer at say, 500hz?
Old 12th December 2004, 06:45 AM   #6
Sure
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.07621 seconds (70.01% PHP - 29.99% MySQL) with 10 queries
