Do PVC vents need damping? I suspect this is so. I'm designing a very intert box with a 4" PVC vent, which will be quite long ~720mm. I'm concerned it could have a bit of a ring to it (as it does when not in a box).
* at what intervals should the PVC be supported? * should damping be applied to the outside walls of the PVC as well? If so, what should I use? * suggestions for alternative vent materials? * any ideas for getting smooth bends? I'm concerned any edges in a typical water pipe bend may cause turbulence.
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#2 |
I've never felt the need to damp them, but one this long needs to be supported at ~62% from the baffle. WRT smooth bends, look at a vent's typical BW vs their Vb, they aren't an issue as long as their cross sectional area is relatively constant, only the terminations if there's a need for reducing vent 'chuffing' due to being too small.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| no air out of my vents | sinfu25 | Car Audio | 2 | 16th July 2009 04:40 PM |
| Aperiodic Vents | MykeysToy | Multi-Way | 10 | 9th March 2008 07:42 PM |
| multiple vents? | kimado | Multi-Way | 1 | 11th January 2007 12:40 AM |
| Ports/Vents | Fazorcat | Subwoofers | 8 | 22nd February 2005 06:04 PM |
| Vents | Vatos | Multi-Way | 1 | 6th April 2003 05:50 AM |
| Page generated in 0.06523 seconds (69.97% PHP - 30.03% MySQL) with 10 queries |
