Old 10th December 2004, 12:58 AM   #1
Speakerholic
Cal Weldon's Avatar
Default Please check my 3 way 12dB crossover design
It's been so long since I did one that I'm not sure I have everything right. That includes the bypass cap for the midrange. The value I want doesn't seem available so I am looking at one either side. Either the 1.0 or the .68. Is everything else OK? It's an LR design
Please note the W and Mid are 16 ohm while the tweeter is 8.
Thanks for your help ahead of time,
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th December 2004, 12:59 AM   #2
Speakerholic
Cal Weldon's Avatar
Guess a pic would help
Old 10th December 2004, 01:50 AM   #3
Bill Fitzpatrick's Avatar
Parallel a .47 and a .33 for the cap you need.
Old 10th December 2004, 01:58 AM   #4
Speakerholic
Cal Weldon's Avatar
Bill,
Thanks for the response. Did you happen to check the rest to see if I'm in the ballpark?
Cal
Old 10th December 2004, 02:27 AM   #5
Well, it's a text book crossover and would be in ballpark if you had zobels across the mid and woof.
Old 10th December 2004, 02:48 AM   #6
Speakerholic
Cal Weldon's Avatar
Thanks Bill. You're a pal. I needed to hear that.
I'll give 'er a tweak it after hearing the initial results.
I wasn't sure where to go, so I went here for my cap and coil values.
http://www.mhsoft.nl/spk_calc.asp
Cal
Can you check this crossover repair job? silentblackhat Solid State 0 10th November 2008 12:55 AM
Crossover Reality Check??? jocko_nc Multi-Way 1 6th February 2007 09:21 AM
check my crossover rv1890 Multi-Way 18 25th February 2006 09:35 AM
Crossover math check jmikes Multi-Way 6 13th December 2004 10:30 PM
Crossover Experts! Hole in 12dB/octave, (both sides), response? Help!! kelticwizard Multi-Way 14 17th July 2002 08:45 AM
Page generated in 0.12691 seconds (56.20% PHP - 43.80% MySQL) with 11 queries
