Old 8th December 2004, 05:35 PM   #1
Default What is the best speaker for 120 watt and 80 watts
I have 2 amps a JVC rx-550vl which is 80 watts per channel RMS at 0.08 thd and the JVC AX-90v which is also 0.08% THD but at 120 watts per channel
I need 2 sets of speakers one for each i wanted to do this DIY but also considering shop bought I want to make 2 sets can anyone recomend the DIY designs for these and the woofers mid rage and tweaters you would rcomend as well as the crossover
I want to spend arround 300 to 500 and want these to respond well aswell sound good when realy powering them
Old 8th December 2004, 06:26 PM   #2
5th element's Avatar
Any you wish to make that doesnt have a really bad impedance with severe phase swings.
Remember the difference between 120 and 80 watts is 1.7dB.
When you say respond well do you mean go loud? In this case you also want good sensativity.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 9th December 2004, 02:39 PM   #3
I ant tto make these 2 pairs of speakers as my first pair of DIY speakers but want to make one that will definatly good what type would be good for these 2 amps any websights cheers
Old 9th December 2004, 03:11 PM   #4
Did it Himself
richie00boy's Avatar
Forget about watts, they tell you nothing. Also don't expect -- as this will be your first speaker -- even though you have a great budget, to make something that will beat a commercial speaker at that price. You will need to learn a fair bit before you get anywhere. If you don't have the time/patience/knowledge then you may be best looking for a kit.
We need more information. What kind of music do you want to play on it? How big will you allow it to be? What kind of volume levels are you hoping to achieve?
Old 10th December 2004, 03:10 PM   #5
Yer this is my first u can tell that easy lol
I am not fused as far as the 120 watt goes but the 80 watt i want to be less than a foot wide and back and im not fused at how high I listen to a wide range of music from rap to some rock and like to have a reasnable ammout of bace withought going ott i also want to watch dvds and vids
Old 10th December 2004, 05:26 PM   #6
dvdwmth is offline dvdwmth  Canada
Here are some popular sites with good designs. Your going to have to read through them and put some thought into whats suitable for you. Stick to the plans. You cant interchange things. Dont try designing your own at this point cause it takes years to learn to do well.
Once you find a few designs that seem to appeal to you, you can get more feed back here. Your current question is kinda vaque which is why your not getting more answers.
http://home.new.rr.com/zaph/audio/
http://home.hetnet.nl/~geenius/
http://www.speakerbuilder.net/web_files/default.htm (the D3 on this site is one of the most popular speakers on the web and its popular for music like youve mentioned)
http://www.audiodiycentral.com/
http://murphyblaster.com/content.php?f=main.html
Here a big list of diy audio links
http://audionova.nu/Innehall/audionova_DIY.htm
the mbow 3way on muphyblaster.com is likely to be one of the best 3ways that will fit in your buget. You could build the mbow 2way, which uses the same midwoofer and tweeter as the 3way, for your smaller speaker. Ordering the same drivers will save you shipping costs. You'd probably have to spend lOTS of coin to get this quality commercially.
I dont agree with the last poster who said that since this is your first project it wont be up to par with commercial designs. If you were trying to design something then yes, but follow almost any design on the links above and your likely to get more than the same money would get you commercially. In some cases alot more.
Give it a shot. You will be glad you did.
Good luck
Old 10th December 2004, 07:09 PM   #7
Timn8ter's Avatar
You might find some ideas in this thread.
Rockin the house
Easy (newbie) Watts & Speaker Question Lash Car Audio 10 8th May 2008 02:02 PM
Speaker Watts dscrobe Multi-Way 28 8th October 2007 10:14 PM
speaker/amplifer volts, watts, ampere, impedance calculator palesha Solid State 11 16th August 2007 04:38 PM
1 Watt in 2 Watts Out .. hmmm ?? Lars Clausen Everything Else 128 17th January 2004 05:38 PM
Page generated in 0.10214 seconds (79.71% PHP - 20.29% MySQL) with 10 queries
