Old 8th December 2004, 07:49 AM   #1
ERICSPEEd's Avatar
Default Fostex kit...
I would like to build this...
FE206E recomended enclosure.
One problem is that the design is built around 21mm plywood. I don't know if I can get the same size thickness here in the US. It wouldn't be much trouble to alter the design to make use of 1'' thick plywood.
What about MDF (not partical board)?
Thanks in advance for your comments and suggestions!
Old 8th December 2004, 09:17 AM   #2
ERICSPEEd's Avatar
I seemed to forget to ask my question... which is...
Should I use quality void-free plywood or MDF instead?
THANKS
Old 8th December 2004, 03:59 PM   #3
MPM is offline MPM  United States
You'll probably get more replies in the full range section.
Old 8th December 2004, 08:33 PM   #4
simon5 is offline simon5  Canada
Void free plywood is a bit better and lighter, but price is higher.
Then MDF is a bit worse, dusty and heavy, but price is lower.
If you use 1 inch plywood, once sandblasted each side, probably 21mm thick?
DIYaudio for President !
Old 8th December 2004, 09:58 PM   #5
I built one of those last spring using 3/4" mdf. If you look at the cut list from the optimized 4x8 sheet, you will note that only a couple dimensions need to be changed. If I recall correctly, the only dimensions that need to be changed were the two sides in height and depth. Everything els fits "in between" the sides.
The problem with this plan is to be sure to design a way to add and subtract stuffing.
By the way, they're heavy. Very heavy.
Old 9th December 2004, 05:38 AM   #6
ERICSPEEd's Avatar
From what I've been reading plywood seems to be the way to go.
I found a place that has 14-ply baltic birch. I guess I'll get some of that.
Thanks for all the replys!
Old 9th December 2004, 02:08 PM   #7
If the ply has to be shipped to you, you might want to consider sandwiching the ply with two pieces of 3/4 mdf. That way the mdf takes a beating and not the ply. Each speaker uses two sheets of 4x8. You could use the mdf in the middle where it doesn't show and the ply on the outside.
Old 9th December 2004, 09:22 PM   #8
Greg B is offline Greg B  United States
21mm plywood is equivalent to 7/8" plywood. It isn't that uncommon. (7/8" ply is really 27/32")
Alternatively, 1/2" mdf or particle board could be laminated to 3/8" plywood. Cascamite plastic resin type glue works well for this. Arguably, that would give you the best of both worlds.
As an added benefit, this may allow you to budget for fancier walnut faced appleply or the like.
I would be very careful about using 3/4" ply and 'adjusting'. Very small changes in horn dimensions can make a big difference, IME.
GB
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 06:00 PM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 07:21 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 01:35 PM
Fostex BLH boonedog Full Range 1 23rd March 2005 08:39 PM
Fostex FE 206 E in ML TL Again levon Full Range 0 16th April 2004 08:02 AM
Page generated in 0.07853 seconds (83.25% PHP - 16.75% MySQL) with 11 queries
