#31 |
Account Disabled
On thicker MDF (3/4" or greater) I assumed that a backing/balancing veneer was not required.
To those who have successfully veneered their speakers without running into long-term issues (bubbling, warping etc), did you use paper backed veneer or raw veneer, and did you use a backing veneer? My veneer is 0.5 millimetres thin, and not paper-backed, and veneered only on one side of the MDF. |
#32 |
Then use lock miter bit!!
anyone here ever tried using lock miter bit? i dont have router table so its too unsafe for me ![]() edit: i meant .. i dont have a router table so its not applicable to me. but just by looking at its cut.. its quiet interesting... |
#33 |
I use paper backed veneer, .010" thk (.25mm). I only veneer one side. I have never had a problem with the veneer, and I have some boxes I did 25 years ago. I use brush on contact cement, coating both the veneer and the enclosure side. I dont know about the permanance of the iron on kind, as I have little experience with it.
#34 |
I've also used 10 mil paper backed, applied with water based contact cement and a stiff scraper. I can't comment on its permanence, but it looks great now.
I sealed the veneer with a coat of shellac and the MDF with an all-purpose water-base sealer. In my tests the bond was significantly better if the MDF was sealed first, and I had no problems with the veneer curling. I don't think a backing veneer is necessary when veneering a box, simply because the box itself holds the panel square. I think this is more of a problem in something like a tabletop or a raw panel. |
#35 |
Paper back veneer works fine and will last many years if applied correctly. It's best to apply two coats of contact cement to both the veneer and the box completely drying the cement after each coat with a heat gun or hair dryer. The contact cement may cause the grain to rise slightly so I usually follow up with a light sanding then clear coat. This is a pic of an MDF cabinet with maple paperback veneer.
#36 |
Timn8ter,
Very nice look. How you manage the corner? Wrap or veneering then cut side by side? |
#37 |
Thanks. It's not difficult to match up grain on paperback since it's a repeating pattern. I cut the veneer with a ~1/4" overhang on each side, glue it, then use a trimmer followed by a file to clean up the edge.
| some veneering questions | JLC7 | Multi-Way | 8 | 14th May 2008 03:46 PM |
| Veneering methods | KennyBradley | Multi-Way | 55 | 11th December 2006 11:46 AM |
| Questions about veneering | sbrtoy | Multi-Way | 33 | 30th October 2006 08:11 PM |
| Help with Veneering | Hefty | Multi-Way | 5 | 6th February 2004 08:45 PM |
| Wrap-around veneering | Gaber | Multi-Way | 10 | 2nd February 2004 08:23 PM |
| Page generated in 0.49873 seconds (19.00% PHP - 81.00% MySQL) with 11 queries |
