Alnico Magnet Question
Old 13th December 2004, 07:14 AM   #11
cdwitmer is offline cdwitmer  Japan
cdwitmer's Avatar
I doubt the magnetism changed significantly between the two in the space of a few weeks. They were probably like that to begin with. As others have mentioned, getting both of them remagnetized is highly recommended. Depending on the design, the magnets can sometimes be remagnetized without any disassembly. Sometimes they have to be partially or entirely disassembled.
"Avoiding deportation from Japan for over a quarter century!"
Old 13th December 2004, 09:49 PM   #12
ulf_audio is offline ulf_audio  Sweden
Hi, bad luck with your magnet. The same thing happened to me once and I made some research regarding Alnico magnets. If you break the magnet circuit it will always lose about 50%. You will need to assemble it and have it remagnetized. Alnico magnets are always assembled and then magnetized.
Check with local magnet suppliers, they usually have a magnetization rigg and may be able to help you. I have some Altec driver that I have remagnetized and it worked OK.
Best regads: Ulf
Old 11th February 2014, 08:56 AM   #13
Rewind is offline Rewind  Sweden
Rewind's Avatar
Best regads: Ulf
Damn. This happened to me too yesterday. I took apart a rusty JBL 2470 for cleaning. Looks good but plays 6 dB lower than it should.
Where should I send it for magnetization?
Old 11th February 2014, 11:51 AM   #14
Baseballbat is offline Baseballbat  Germany
Read about magnet load lines, e.g. here: DYNE Analytics • View topic - Magnetic Load Lines
Alnicos have a very "curvy" so-called intrinsic curve. As soon as the magnet is put under load (that means the magnetic flux "sees" some resistance, for example an air gap) the magnet gets partly demagnetized (depending on the load). It won't demagnetize any further as long as the load isn't increased, but you'll have to magnetize it again to bring it back (and it will demagnetize itself at once if the load is still there). Therefore magnetized Alnicos should not be disassembled.
Neodyms or Ceramics have a nearly rectangular curve. They won't get partly demagnetized under load, but if you push them too far they're nearly completely demagnetized.
Old 11th February 2014, 12:21 PM   #15
Rewind's Avatar
Yes, I have learnt this through stupidity. Now the question is where to magnetize my JBL 2470 in Northern or Central Europe.
Alnico Magnet QuestionHide this!Advertise here!
magnet design 101 - saturate iron with a ferrite magnet? capslock Multi-Way 18 28th April 2010 04:51 AM
speaker magnet proximity Question pango Tubes / Valves 2 21st August 2007 06:38 AM
unbranded speakers - Alnico Magnet? ErikdeBest Multi-Way 13 10th October 2005 08:48 PM
Bucking magnet question woody Everything Else 1 1st June 2002 07:55 AM
