New version of The Edge baffle step simulator
Old 3rd December 2004, 07:44 PM   #1
Svante is offline Svante  Sweden
Svante's Avatar
Default New version of The Edge baffle step simulator
Version 1.5 of The Edge is now available at http://www.tolvan.com/edge
From the docs:
Added in ver 1.5
- Correction of the way the strength of the edge sources was calculated. Previously, the amplitude reduction of the edge sources by the distance law included the driver-to-edge distance. This was wrong, since this part has already been taken care of when dividing the edge in sectors seen from the driver sources. A slight difference from this change can be seen when the microphone distance is near or shorter than the dimensions of the baffle. The effect of the change is a lowered level at low frequencies in the new version.
- Hint text changed (+3dB -> +2dB) for "Suggest f1 & f2" button.
-The minimum number of corners, edge sources and speaker source density is now 1. This makes the editing of these values slightly more well-behaved, even though there still are issues (which are related to the implementation of the spinedit control in Delphi).
...in other words; I found a small error in the way the response was calculated, this is fixed, and so are a few other mini-quirks.
Have fun!
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 3rd December 2004, 08:03 PM   #2
tiroth is offline tiroth  United States
Thanks Svante! This is a really good, professional quality program.
Will you ever consider allowing different shaped/sized drivers? (That is, 1" rectangle plus 8" circle?) I often use your program to do polar response predictions, and I just fudge things as needed. xDir is nice too but not nearly so flexible as the Edge for multiway modeling.
Old 3rd December 2004, 08:13 PM   #3
Svante's Avatar
It will not happen in The Edge. Maybe there will be another program one day...
Old 3rd December 2004, 09:51 PM   #4
Kittle is offline Kittle  United States
Definately good stuff! Thanks for your work.
Any plans to indicate frequency ranges for the various drivers?
Old 4th December 2004, 02:04 AM   #5
Joules is offline Joules  United States
Joules's Avatar
Great program immensely usful ... Kudos to you
how do you turn off the recalculation, so I can change values with out instant recalculation.
Thanks a million!!
Old 4th December 2004, 09:21 PM   #6
Svante's Avatar
Fourth button from the left...
Old 6th December 2004, 08:05 AM   #7
Joules's Avatar
Any posibility of getting radiused and chamfer baffel edges with that ?
Old 6th December 2004, 09:26 AM   #8
Svante's Avatar
No.
Old 6th December 2004, 03:24 PM   #9
Joules's Avatar
"No."
That's to bad.
I keep getting a small hump at the transistion from 4pi to 2pi radiation and I'll bet a radiused edge would help.
Svante- I just saw your Xdir thingy. Thats really neat. I've
been looking for something like this for a long time.
what would be realy cool would be a slide pot for the freq. so you could get a quick impression of how the pattern changes. Even if the calc's have to be sub divided into 3rd octive steps
And as long as I'm in fantisy land ... To be able to asign an xover filter (freq and order) to the T's and M's and then be able to slide pot the input freq would be just the cat's pajmas.
Svante - You da' man
Old 7th December 2004, 07:21 AM   #10
agrobler is offline agrobler  South Africa
Question:
If I have following set-up in classical MTM arrangement top to bottom...
woofer < 315Hz
tweet > 1800 Hz
Fullrangemid < 1800Hz
Can I just use the tweeter woofer option in Xdir? because at 315 Hz with 165mm drivers they will be dispersing heaps, no need to worry about the directivity...
Cool programs - will see if they predict my perceived problems... then we will know what to do about them problems...
Thank You!
New version of The Edge baffle step simulatorHide this!Advertise here!
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 23 12th February 2013 03:23 AM
Baffle profile baffle edge problems? otto88 Multi-Way 5 5th November 2008 02:17 AM
Target 3001 Version 11 / 12 Schematic, PCB and Simulator Program, who's using it?? John Biles Everything Else 9 31st October 2005 12:27 PM
Need help using "Edge" to design Baffle Step Correction Circuit please. G Multi-Way 5 3rd July 2004 11:49 PM
The Edge simulates the baffle step. Svante Multi-Way 0 30th March 2004 01:33 PM
