Old 3rd December 2004, 11:14 AM   #1
Deodato is offline Deodato  Netherlands
Question Supravox 215 RTF data
Does anyone have distortion/spectral decay/impulse response data from the Supravox 215 RTF wide range driver?
http://www.supravox.fr/
I know this kind of speaker tends to be judged subjectively only, but I guess I want to be biased with some objective data.
Old 3rd December 2004, 12:22 PM   #2
Stixx is offline Stixx  Germany
Stixx's Avatar
That's why I would try to have a good listen to them and not judge by the numbers. What counts is how they sound....
Oliver
Old 3rd December 2004, 01:06 PM   #3
vuki is offline vuki  Croatia
vuki's Avatar
In number 57 of italian magazine "Costruire Hi-fi" there were measurements of Supravox 215RTF and few other full range drivers.
However, measured were only freq. responses on (0 & 30 degrees), ac. phase . and impedance. If interested, I could try to make a photo of that page and send you a picture because I don't have scanner.
It looks like very nice driver but it needs tweeter over 10kHz.
In Paris I listened to open buffle 3-way with Supravox 285, 215 & Beyma Cp21f and it sounded very nice.
Old 3rd December 2004, 07:18 PM   #4
That's how I intend to use Supravox 215 RTF, though I'll cross lower. I know there are other good 8" midranges. I need 8" because I'll use it in an open baffle design. Supravox 215 RTF would be the easiest to use (reasonably flat SPL/Freq) and pretty good to the eye, too (looks do matter to me and very subjectively so). If just want to be sure about the other data... At Supravox they couldn't help me either.
Old 3rd December 2004, 11:36 PM   #5
Sjef is offline Sjef  Netherlands
I'm using the Phy-HP LB21 on a open baffle with woofers and ribbon tweeters crossed at 100Hz and 5kHz. The Phy has highly identical specs as the Supravox (and I guess they have a highly identical sound character as well). Since you also live in Amsterdam you are welcome to come over for a listening afternoon.
OB supravox VS scanspeak=5-0 nicoch58 Full Range 3 25th May 2008 12:10 AM
Supravox OB tomitune Vendor's Bazaar 0 3rd March 2007 01:17 AM
Supravox OB InclinedPlane Full Range 4 2nd March 2007 10:07 PM
supravox 285gmf jensen +supravox fronthorn Jacobus Multi-Way 3 16th August 2006 12:15 PM
Fertin & Supravox i_should_coco Full Range 2 5th June 2006 12:21 AM
Page generated in 0.08708 seconds (73.55% PHP - 26.45% MySQL) with 10 queries
