Will routing edges of front baffle affect sound?
Old 2nd December 2004, 04:15 PM   #1
Ken C is offline Ken C  Canada
Default Will routing edges of front baffle affect sound?
I'm building 2 pairs of bookshelfs right now, 8-3/4 in width.
One pair is for me, one for my cousin, and we'd like to dress these up just a bit differently.
He'd like rounded edges on the front baffle along the right and left sides. I'd like to have a 45 degree cut angling them back. The router bits will both cut 1/2 inch, so approx 1" in total of the baffle is going to get shaved a bit...
I've seen some of Dennis Murphy's views on the roundover not making a big difference, but will the 45 degree cut do much?
Any thoughts?
Old 2nd December 2004, 04:50 PM   #2
tiroth is offline tiroth  United States
It won't do too much. AudioXpress did some measurements, and unless I am remembering incorrectly, only the 1"+ bits had much effect. It could be worth digging out that article if you are really serious about it; they have back issues on CDROM.
Another way to do this if you have a table saw is make the baffle thicker and make the angle cuts right on the saw.
Old 2nd December 2004, 05:34 PM   #3
5th element is offline 5th element  United Kingdom
5th element's Avatar
It may not do an awful lot for diffraction but it certainly looks a lot better, allowing you to make the cabinet slightly wider and still keep a slender look. This does require a lot more work if you are finishing the loudspeaker with veneer, because you need to put insets of wood in around the veneered parts so you can route them.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 2nd December 2004, 06:39 PM   #4
Example of what I just said.
Old 2nd December 2004, 06:50 PM   #5
Default Hmmm not sure I follow, 5th element
I haven't had a problem wrapping the veneer around the rounded-off edges of my other speaker projects, but I just never considered the effect on sound the cuts would have...for the 45 degree cuts (which on the wood I suppose is really what, 135 degree angle) The rolls of veneer I usually buy easily wrap, or you can cut in pieces and hide the seams very well on edges...
Old 2nd December 2004, 08:23 PM   #6
Hmm I never considered putting the veneer round the corners I just assumed it would be very difficult to get right.
Old 2nd December 2004, 08:31 PM   #7
Well, it ain't easy, but it's certainly doable.
I just built 8 stands for the ar.com DIY projects I'm building as my new Home theater upstairs so I can move my towers into my studio...we wrapped veneer around the octagon pillars of these stands without problem at all...this was difficult. Speakers are way easier because they're larger, flatter surfaces with less corners:
http://ca.geocities.com/sdupre0828@r...ker_stands.htm
err...I'm still learning about uploading thumbnails onto the webpage, not the greatest pics until you blow them up.
Old 2nd December 2004, 10:18 PM   #8
aaroncgi is offline aaroncgi  United States
Default Great stands, Ken!
Ken,
Those are some beautiful speaker stands! I can't decide if I like the rounded bases or mitered bases better. I love the hexagonal veneered center post though, something I don't think I've ever seen in commercial stands. The price is sure right, too.
Aaron Gilbert
Old 2nd December 2004, 10:42 PM   #9
ultraman is offline ultraman  United States
I've had no problem wrapping veneer around a 1/2 inch radius. The corners on those speaker stands is more than I thought it could do without splitting. They look great.
Going around corners gives a more solid appearance to a cabinet. Just always, ALWAYS, go with the grain of the veneer lengthwise over the bend.
Old 2nd December 2004, 11:04 PM   #10
catapult is offline catapult
Dennis Murphy changed his mind and found that a 3/4" roundover significantly smoothed the treble, both on and off axis. He has some sample response curves on his website.
http://murphyblaster.com/content.php?f=cabinets.html
Will routing edges of front baffle affect sound?Hide this!Advertise here!
Zero Baffle Width, Zero Edges...Sort of.. BlueWizard Multi-Way 38 7th June 2017 09:57 AM
Can a power cord affect sound quality?? sully Parts 193 14th November 2013 11:13 PM
solution to those who say that LED's affect the sound adversely elizard Everything Else 59 13th March 2006 06:48 AM
Does sloped baffle affect X.O. dvdwmth Multi-Way 3 3rd June 2004 10:47 PM
does the resistor's ppm affect the sound? mekanoplastik Parts 9 4th June 2003 05:21 AM
