hello,
i am very new to diy i have recently built 3 subs. thing is that i have a harman/kardon avr 3550 receiver. 85wx5 i dont have a center channel. i am thinging of building a chenter my self. son can any one give me a idea of how i can build it. i am willing to use fullrange drivers and a piezo tweeter. wut tweeter should i use? like piezo or a papercone tweeter? ( keep in mind i live in india we dont get any drivers from fancy international brands so its all local stuff) also r fullrange drivers good or should i use woofers? if its a configuration of 2 drivers and 1 tweeter, can i connect all in series and the tweeter in paralel and connect it to the amp? or do i need to put some capacitors and resistors? should i make a ported enclosure or a sealed one? i think loudspeaker making is much easier than making a sub.
Sidd+5.1=madness |
#2 |
Did it Himself
Speaker making is NOT easier than sub making as there is the crossover to consider
#3 |
Did it Himself
As ever, whether the box is sealed or ported will depend on the drivers you use.
It might be nice to try a fullrange design with a piezo tweeter just coming in for 8-12kHz and up. This means you don't have a crossover in the voice range so it should sound quite coherent and natural providing you source a nice fullrange driver. You may also be able to get away with a minimal crossover which will be easy to design. The downside (if you can call it that) of this approach would be that the box would have to be an upright design as opposed to the more common, horizontal, lay-down type. |
#4 |
Your driver will need to be shielded if your TV is a CRT type, or the stray magnetic field will distort the picture. The piezo tweeters have no magnet, so they wont be a problem. Just put a 8-10 ohm 2W resistor across the piezo terminals, and use a series cap of about 2 or 3uF to tie them to the woofer terminals. It is quick and easy, and should work reasonably well.
#5 |
The easiest thing to do is use a shielded fullrange driver like the CSS WR125S @
www.creativesound.ca I have one of these in a ported box sitting on top of my TV right now, just waiting for laminate to arrive to finish the boxes. The sound is VERY good, and stays locked to the picture at all times. No crossover, just design an appropriate box, stick your driver in, and run a wire to your reciever. If you have no access to crossover design tools or measurement equipment, this is your best bet, or use a respected kit like the Adire LCC or Audax HT center channel. |
#6 |
hey hornlover,
i am planin to use two 3or4 inch woofers and a piezo. so do u think i should use fullrange or woofers? and abt that crossover u told me abt, ur sayin that i put a resistor or 8-10 ohm in parallel to the tweeter and put a 2 capacitors that is one with each woofer, -(speaker)-(capacitor)-(tweeter)-(capacitor)-(speaker)- l resistor l so is this the arrangement ur talkin abt? and wut ohm woofers or fullranges should i use? will the speaker sound good if it has a high resistance? like 15 or 20 ohms on my harman/kardon which has 85rms x 8ohms cuz over here in india i am not gonna get speakers that are too good in the wattage section and quality section. so like if the speakers has more resistance i think the amplification will be less. and can u give me the dimensions of the box? i have leftover 3/4" mdf i used 4 making a sub last week. its approx 2feet x 4feet sheet.
Sidd+5.1=madness |
#7 |
come on guys send me ur replys so that i can buy the stuff
Sidd+5.1=madness |
#8 |
Did it Himself
You put a resistor in parallel with the tweeter. Then in series with this tweeter/resistor combination you put a capacitor to roll off the bass and mid. You don't put anything on the woofer.
This is a very crude crossover but will be OK for a starting point. Hornlovers capacitor value would be OK for 4 inch woofer. You might want to add 2.2 ohms >2W or so in series with the tweeter capacitor though as I think you will find it too bright. I'd also use >4W for the 8.2 ohm resistor. |
#9 |
A piezo tweeter doesnt need a cap to protect it, and a lot of people just parallel the piezo with the woofer and use it as is. In my opinion, this makes it sound a bit harsh, since the piezo is working in the midrange, where they dont perform as well as in the higher frequency range. That was the reason for the resistor in parallel with the piezo. This allows the series cap to see a resistive load, and now you can select your capacitor value to roll off the midrange frequencies, allowing the piezo to work in the higher frequencies only. Just one series cap is needed, with its value based on first order crossover formulas (with the series resistor value used as the impedance). This is a very simple way to cut the piezo in at higher frequencies, and as richie))boy pointed out, you may want to attenuate the piezo, depending on the sensitivity of your midrange (or woofer) driver. As for the woofer, you want to make sure it can respond up to the point you choose for your piezo to cut in.
#10 |
ok guys i have bought a 4" woofer and a dome tweeter. they both are local quality dont expect too much.
the woofer looks good as it has a big magnet and have a plastic cone. my problem is that the tweeter is not sheilded so wut should i do, can i do any modifications so that i can place it on top of a the tv? i have heard a piezo tweeter its toooooooo harsh on the ears it makes ur head ring. so i desided to use a dome tweeter. the tweeter is i think 4ohm and the woofer is 8ohms i am gonna use 2 such woofers. so do u think i should put everything in series with one capacitor of 2.2uf ? does higher resistance cause any trouble? cuz like is have a really high power amp so i guess high resistance will reduce the amplification right? so can u tell me the box dimensions i have a 2 x 4 foot mdf piece so wut should be the dimensions 4 the best o/p? so that i can start workin on it?
Sidd+5.1=madness |
| Need center channel help | Ryan_Mc | Multi-Way | 0 | 12th February 2009 03:36 AM |
| center channel?? | wicho | Multi-Way | 1 | 25th October 2008 01:01 AM |
| Center channel with one mid | Buzzy | Multi-Way | 11 | 17th October 2008 03:52 PM |
| T-amp for Center Channel? | atleer | Class D | 3 | 6th August 2007 04:56 PM |
| Center Channel | bhg41088 | Multi-Way | 1 | 5th September 2004 01:57 AM |
| Page generated in 0.12028 seconds (76.47% PHP - 23.53% MySQL) with 11 queries |
