To support the growing number of crossover simulation-tool users I have done a series of measurements that might be useful for you.
The idea was to build a cabinet that should be close to what is being used in a normal 2-way application and supply data that could be used in a crossover simulation program. This box is built to fit our 18cm woofer chassis, and the tweeter baffle is removable - to be able to use different tweeters. All woofers and tweeters are measured flush mounted. The data is available in .txt files with tabulator separated data coloumns. Please note that there will be differences to the measurements found in our datasheets. The main reason for this is the different boundry conditions. In the datasheets the tweeters are measured in a baffle and placed off-center to smooth out the baffle-edge diffraction. In the box measurements this diffraction is affecting the measurements quite a bit. To receive a 350kB .RAR archive, send an email to: bidland at seas.no Bjorn Magne Idland Lab technician, Seas Fabrikker AS |
#2 |
Greeting!
I know this is an old post in 2004. I hope you can still help me on the SEAS 22TAF/G spice parameters please. Thanks! |
#3 |
| Use Orcad for speaker / crossover simulation | alexw88 | Multi-Way | 6 | 16th March 2011 03:08 PM |
| Crossover simulation | Vivek | Multi-Way | 9 | 28th August 2008 11:02 AM |
| Simulation Results: Dayton RS180 / Seas 27TBFC 2-way Bookshelf | Jay_WJ | Multi-Way | 97 | 19th June 2007 10:05 AM |
| Real PC Simulation of Crossover? | Mikett | Multi-Way | 6 | 25th September 2004 11:36 AM |
| Page generated in 0.09017 seconds (71.02% PHP - 28.98% MySQL) with 10 queries |
