I can't seem to find anything authoritative on acoustic measurement of horns, so I apologize if this has been covered already: is a nearfield measurement accurate for a front loaded horn? I would imagine that the microphone is placed in the plane of the horn's mouth?
#2 |
Banned
Is it accurate how? It is if you're trying to measure the nearfield response. The usual method is outdoors from 2 or 4 meters away, extrapolating to arrive at 1w/1m.
#3 | |
From Claudio Negro (thanks!)
#4 |
Banned
If you measure outdoors at a distance those problems are overcome. If you can't then you measure at, or as close as is possible to, the systems radiating plane, which in the case of a horn is the horn mouth.
#5 |
I appreciate your suggestion Bill, but I'd like to know if this is actually part of the special case of the nearfield measurement. It sounds to me that you don't think so.
#6 |
Banned
It is, but it's not the preferred method for measuring horns. The reason is that with the mic in the mouth you're going to be measuring phase induced anomalies caused by reflections off the horn sides, which are considerable because of the size of the mouth relative to the frequencies passed; this doesn't present much of a problem when measuring direct radiators. Horn responses need some distance from the source for the response to settle out, preferably at least 4 times the distance across the mouth. Measuring at the horn mouth will show a lot of peaks and dips that don't show up when measuring from a distance.
#7 |
Thanks very much! Exactly what I was looking for.
| Nearfield ribbon? | 8675309 | Planars & Exotics | 5 | 4th August 2007 05:57 AM |
| Nearfield listening | xyrium | Multi-Way | 3 | 10th July 2006 10:35 AM |
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 10 | 27th December 2005 09:10 AM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
| re: nearfield monitors | jeantofte | Multi-Way | 5 | 12th October 2002 10:27 AM |
| Page generated in 0.08641 seconds (79.29% PHP - 20.71% MySQL) with 10 queries |
