Old 30th November 2004, 12:04 AM   #1
Mr Evil is offline Mr Evil  United Kingdom
Default Isobaric horn + Hornresp
How would I account for two drivers in isobaric configuration in Hornresp? Usually it's simply half Vas, leaving everything else alone, but Hornresp takes no account of Vas directly. My instincts tell me that Bl and Mmd would double, but I'm not sure.
If the answer to that is not forthcoming, perhaps someone would at least know if two isobaric drivers would increase or decrease the overall required size of the horn, or if there is any other configuration of two drivers that might decrease the horn size, or at least not increase it (I have two drivers and don't want to leave one unused).
https://mrevil.asvachin.eu/
Old 30th November 2004, 12:17 AM   #2
Brett's Avatar
Default Re: Isobaric horn + Hornresp
Why would you want to? The load on each driver would be quite a bit different I would think.
It's hard enough to design really good sounding horns with one driver. Practice with that first.
But to directly answer your question, go to Professor Leach's site and download his spreadsheet, that'll give you more info to load into Hornresp.
Old 30th November 2004, 01:48 AM   #3
Default Re: Re: Isobaric horn + Hornresp
I have no idea why I would want to horn load an isobaric pair of drivers, that's why I want to find out what will happen
I had a quick look at Prof. Leach's site but couldn't find any spreadsheets.
Old 30th November 2004, 07:38 AM   #4
you could shorten your horn by using the two drivers in parallel. but your back box now needs to be twice the size. Total volume might end up the same or worse.
regards Andrew T.
Old 30th November 2004, 03:29 PM   #5
A long long time ago I bought sixteen 18" woofer (Eminence clones) do create an isobaric folded horn for a van but I never completed the project. I did a test box with two woofers (isobaric/horn) and it worked. Satisfy your curiosity and build a test box out of cheap wood to see what happens.
Old 30th November 2004, 03:56 PM   #6
Mudge is offline Mudge  United Kingdom
Bizarrely I'd not looked at the forums for awhile, but was looking into the theory behind Tom Danley's new APB design. The APB is a very small (by horn standards) twin bass horn. The basic design is a very short conical horn, with a small mouth and throat far below Sd. Two of these horns are paired in one enclosure and both drivers use the same rear chamber.
Just for kicks I used the LAB12 parameters, 80L rear chamber, combined mouth size of 600 sq cm, 37cm path, 10:1 Sd:Throat ratio, drivers wired in parallel. The impedance curve doesn't drop below 5.5 Ohms (despite the parallel wiring) and the sensitivity stays above 95dB/2.83V till below 30Hz
The only problem is that rear chamber size, I'm going to look at other popular high X-max drivers to see what else is possible.
Mark
The king of all that is evil has left the building
Old 30th November 2004, 08:56 PM   #7
Mudge,
do you have more info on the APB-1 ?
I took a look at the servodrive site and at prosoundweb but didn't find anything..
i'll try to duplicate your simulation when i have time
Old 30th November 2004, 09:33 PM   #8
This thread on the SPLBoard discusses the APB . Other than this I have no knowledge of the APB. I have to give full credit to Tom, he is a genius, he figures out ways to use horns that most of us would never come up with
EDIT: My sims use the LAB12 parameters as provided by Eminence. I use Hornresp to simulate a single driver with a 300 sq cm mouth, then use the multiple horn option to simulate the effect of two close coupled.
Mark
tapped horn isobaric drivers bubblersound Subwoofers 4 18th June 2009 02:42 AM
Help me simulate a Le Cléac'h horn from hornresp sqlkev Multi-Way 9 12th September 2008 08:07 AM
horn lengt in hornresp crissty Multi-Way 8 5th January 2006 10:04 AM
Page generated in 0.09205 seconds (79.69% PHP - 20.31% MySQL) with 10 queries
