Hi all. What do you think about this kind of speakers?
http://www3.ocn.ne.jp/~hanbei/eng-whyspiral.html http://www3.ocn.ne.jp/~hanbei/eng-how.html http://www3.ocn.ne.jp/~hanbei/eng-boxmodel.html http://www3.ocn.ne.jp/~hanbei/eng-helixl100.html I like the Helix L-103( for dimension, looks and cost but I've not experience with diy loudspeakers so I need help to evaluate it ), in the bottom of this page: http://www3.ocn.ne.jp/~hanbei/eng-linearmodel.html Thankyou in advance Mark |
#2 |
Glup - I think you are very brave attempting this complex spiral construction as your first speaker project.
I'd start off perhaps with same driver in a simple BR box and if you are happy with driver try a more complex enclosure.? Fostex get good reviews for full range drivers. I'm going to try one for a new project in a few months but I don't think I'd have the patients to try this spiral port design Good luck. |
#3 |
Well...the great problem is chose the speaker ( I want something with good sensitivity for my diy tube amp) then I'll try different solution, indeed this one will be one of these...and BR too
1) sensibility>90 Db ( I want to use good low power amp(5/15W). 2) dimension...I have to lay the loudspeaker on a desk 76cm high. Not a good solution indeed, but this is my condition in this moment. Max dimension: 50*30*30cm 3)cost: 200€ max Mark |
#4 |
I was thinking about giving these a shot for my FE206E's. Everything is straight forward construction except the spiral and you don't have to insert it until it's right. To make the spiral I was thinking of stringing a bunch of popsicle sticks on a threaded rod. Put enough pressure that they hold their position. Splay them to form the spiral and tighten it down. A couple of layer of fiberglass resin and fiberglass cloth to stregthen it. Sand the edges for a perfect fit and slide it in.
Everyone has a photographic memory. It's just that most are out of film. |
#5 | |
Hi johninCR, I'm not sure if I've understand how you think to make the spiral. About the popsicle sticks, you mean to fix one side of them in the screw thread...right? With glue I think... Since the tread pitch isn't the same of the spiral ( that isn't constant too) you can glue the sticks each other ( they are partially laid one at top of the others). Than the fiberglass layers to stregthen the spiral pattern. Ok? I'm right? It seems straight forward indeed, I'm only afraid by the weight of the rod, that, sooner or later, might warp the spiral or even weaken the sticking. I think we have to consider this aspect. Maybe a good solution will be to carve the way of the spiral on a wood rod and put in the posicle sticks ( you can glue them with vinyl glue). Then you'll use the fiberglass...how does it looks? Sorry for my bad english...I hope my answer is comprehensible Mark |
#6 |
The threaded rod would need to be thin unless you used tongue depressers (like doctors use). Drill a hole near one end. Put them all on the rod. Tighten with nuts and washers on both ends. Line them up uniformly and clamp with a wood clamp. Cut them slightly longer than needed. Sand the ends to the proper length and very slight arc. Maintain the correct amount of pressure with the rod and nuts to splay them into the proper spiral, probably using a little glue as you go. Then proceed. At the end, remove the rod if you want and seal the hole.
Mr. Takenaka told me he thought sealing gap between the spiral and the sidewall of the pipe may be difficult with this method. Small pieces of a thicker wood may be less problematic, but would require more filler to make the spiral very smooth. Maybe his cable method is easier to get right than it seems. The wood cutout method he shows is far too much work unless you have access to a CNC robotic router. My idea seemed cheap and easy enough to try.
#7 |
Has anyone actually critiqued the design theory? I remain skeptical that the spiral does what the author/designer says.
I don't mean to say that it does not do what is said, but I mean to say that I remain skeptical until I see some independent data. Dave |
#8 | |
Hi kneadle...this is the reason why I post here...I found nothing over this design. I You think someting about plese post your opinion. So why don't you think the spiral does what the author says? |
#9 | |
The following paragraph on his site concerns me:
Dave |
#10 | ||
) Unbeliever or not I hope your critique open the discussion, because I think that this speakers, if they really do what the designer says, will be a good solution for a large number of people. They are small, with good looks and they seems able to reproduce a better LF than a standard bass reflex ( for a fullrange like the Fe127 obviously!). Maybe I'm wrong because I start with diy only last year and my attention since today was for tubes Quote:
http://www.t-linespeakers.org/projec...uke/index.html Mark |
| double horn, bib or angular spiral horn? | testarossa2k | Full Range | 49 | 18th September 2011 03:03 PM |
| giant spiral horn | el`Ol | Full Range | 0 | 14th May 2007 08:31 AM |
| Spiral horn or TL? | Ang | Multi-Way | 4 | 9th May 2007 11:49 AM |
| spiral PVC horn fostex 108 sigma | rtlbuilder | Full Range | 2 | 22nd April 2006 04:40 AM |
| Page generated in 0.37682 seconds (45.29% PHP - 54.71% MySQL) with 11 queries |
