thanks GM for looking in to it.
in the catalog it says "midbass" so how do i implemented it? as a bass augmenter like the hornshoppe hornline? or as a sub? a good candidate? i see 10 db rise in 1-2 khz region |
#2 | |
Well, if the specs are ~accurate it has a 25.8Hz Fb T/S max flat alignment, so this makes it a woofer and as good a performer as some marketed as 'subs', and in a pipe will be tuned a bit lower. That said, if you optimize it so that you can't drive it beyond Xmax at its rated power, then yes, it's only good down through the midbass BW. The vent gets unacceptably long though, so sealed or aperiodic is preferred if used as only a midbass. WRT its breakup modes, ideally you're going to be XOing low enough to attenuate these to inaudibility, otherwise you will have to damp them with either a notch filter or an inductor to roll them off in addition to whatever XO you use. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| OB passive xover w. augmenter - or BLH? | freddi | Full Range | 0 | 16th April 2007 04:03 PM |
| "El Cheapo" DVD candidates thread | yldouright | Chip Amps | 25 | 8th January 2005 06:04 AM |
| low distortion bass system for jx92s | _henry_ | Subwoofers | 6 | 28th November 2004 12:26 AM |
| Page generated in 0.14322 seconds (39.19% PHP - 60.81% MySQL) with 11 queries |
