Old 28th November 2004, 08:38 PM   #1
klitgt is offline klitgt  Denmark
klitgt's Avatar
Default Diagram of B&W CM2
Do any of you have the schematic diagram of the crossover curcuit in the B&W CM2 loudspeaker?
I ask because I want to know which of the 2 caps (10uF and 4,7uF) is in the direct signal path to the tweeter.
I could take out the PCB but it is rather difficult and requires gynecologist skills to operate through the hole that appears after removing the bassreflex tube at the back side of the cabinet.
I wonder whether replacing the caps (yellow rectangular plastic caps, probably styroflex types) with paper-in-opil types may improve the sound.
And if it is possible to replace only one of the caps will reduce the huge cost of aquiring a pair of paper-in-oil caps.
;-) Torben
Connection Diagram for ESX 600.5 JoergST Car Audio 0 31st August 2006 07:32 PM
Can someone look at this diagram for me? warnsey Full Range 5 31st May 2006 01:21 AM
Diagram STK407-090 panterka Chip Amps 1 24th April 2006 06:24 AM
Schematic diagram Matthewong Pass Labs 29 12th August 2005 03:39 PM
B&W 801/802 diagram aarsoe Multi-Way 5 28th March 2005 05:16 PM
Page generated in 0.06948 seconds (52.18% PHP - 47.82% MySQL) with 10 queries
