Old 28th November 2004, 09:51 PM   #1
Mjr7531 is offline Mjr7531  United States
Mjr7531's Avatar
Default Self-Amped Comp Speakers
Hi, I'm a newbie here, I've mostly bought premade speakers, but now I want to jump into DIY world.
My sister said she wanted computer speakers for Christmas, so instead of buyer her some cheap ones, why not make em'.
Anyways, I thinking a Tang Band full range, http://www.partsexpress.com/pe/pshow...number=264-820
coupled with a stereo kit, The only one on Parts Express is a 15 wpc @ 4 ohms, and I do not want to buy two drivers per cabinet to get that 4 ohms, are there better kits out there, or will I have to settle with that.
Also, would it be wise to do dual chambers (sealed from each other)? One for electronics, and the other for speakers? Any and all advice would be apreciated (As always, cheaper is better.)
Thanks for putting up with my long winded post,
Matt
Old 29th November 2004, 02:04 AM   #2
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
IMO you would want a tweeter with that 4" driver. Why not use the 3" PPM version instead? Or the TB W3-871S (search for it on the forums, you will get tons of hits).
Wouldn't you rather build a 2.1 system with a bass module?
KTK. Kool To the Kore.
Old 29th November 2004, 07:56 AM   #3
Mjr7531's Avatar
I would like to, but I'm rather Strapped for cash, and a Bass Module is out of my budget, I figured, two drivers and no crossovers would make it much cheaper and easier to design.
Old 2nd December 2004, 01:41 PM   #4
MPM is offline MPM  United States
Try the JBL amp here
www.apexjr.com
Its pretty cheap and functional.
Old 2nd December 2004, 03:59 PM   #5
jjdche is offline jjdche  United States
I built something similar with the TangBand W3-871s and the Velleman amp kit. If I did it over again I think I'd go with a different amp. When you factor in the cost of a transformer and connectors, volume, etc. it becomes a bit expensive compared to some other options out there. Parts Express has the Sonic Impact T-amp for about $30 or the amp at AllElectronics.com. Both of those are pre-made solutions that will save you a few dollars.
Bi-amped speakers? Worth it? stoc005 Multi-Way 9 24th January 2009 12:31 PM
Amped HDS Speakers Noobie_Steve Solid State 0 7th September 2008 06:08 PM
Looking for a 2-way shielded setup for comp speakers.. Fryguy Multi-Way 0 6th August 2003 10:12 PM
Just bi-amped my speakers. Jean Multi-Way 10 25th February 2003 05:29 AM
Page generated in 0.07890 seconds (70.25% PHP - 29.75% MySQL) with 10 queries
