Old 28th November 2004, 04:55 AM   #21
"geil" translates best as "horny", so "geiz ist geil" is a new attitude in germany. It sort of means that the cheaper one can get things short of fraud the more thrilling it is. Your translation hits it very well - greed is great. I think things are not that different in the states.
Interesting is - something for psychologists i guess - the connection between the sexual and the purchase of goods.
Old 28th November 2004, 10:06 AM   #22
Here:
http://purebits.com/miccomp.html
I made some comparison of the following microphones:
- BRUEL & KJAER 4190
- Sennheiser electret capsule KE-4
- Panasonic electret capsule WM-61B
It's interesting to see that the frequency responses of the different microphones are quite similar! Probably the B&K mic has better S/N ratio and better specifications, but this test proves that the inexpensive Panasonic WM-61B capsule is quite usable for loudspeaker measurements.
The KE-4 are slightly better than the Panasonic (I use them from long time) but they seem not more in production.
Old 28th November 2004, 02:56 PM   #23
jackinnj's Avatar
Default Mitey Mike
Decades agoSpeaker Builder had an article on called "Mitey Mike" -- they used an inexpensive Panasonic cartridge mounted in a thin tube -- Old Colony sells a kit linked here:
http://www.audioxpress.com/bksprods/kits/kd-4.htm
-- you can probably dig up the schematic and article for the original, there are also some knock-offs and improvements floating out there on the web.
Extended range measurement mics and pre-amps percy Multi-Way 1 17th November 2007 02:55 AM
Elation mics bernification Everything Else 0 23rd July 2007 12:24 PM
MXL 770 mics - any mods? Wavebourn Instruments and Amps 7 27th October 2006 11:16 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 09:08 PM
Sample Champion and measurement mics? BenLilly Multi-Way 1 11th March 2003 06:24 PM
Page generated in 0.10188 seconds (65.83% PHP - 34.17% MySQL) with 10 queries
