I'm about to build a version of Tim Forman's bipole voigt pipes using 4" RS 40-1197 drivers, which call for ports of 1.75" dia x 2" long. Is it worth having radiused/flared ends on the ports? I have read somewhere that radiused ends necessitate a change in port dimensions. Can anyone advise as to what to do here?
Cheers!
"Everything should be made as simple as possible, but not simpler." - Einstein |
#2 |
if you widen the port then you need to make it longer.
a good starting point would be to make sure at least the non flared section of the port is at least 2" long. if the tuning is too low then you can make the port shorter bit by bit until it sounds right. |
#3 |
Thanks. If I remember right (after I wrote the above), I read that the rule of thumb is that for a 1" radius, 1" needs to be added to the length. Another way of saying the same thing, but I think your explanation is clearer.
Cheers!
| port question | phillfyspoon | Subwoofers | 8 | 3rd March 2006 04:39 PM |
| Port question? | mace | Subwoofers | 6 | 10th December 2004 12:21 AM |
| Idea: inner end of port angled, not flared | Datoyminaytah | Multi-Way | 6 | 20th August 2004 09:34 PM |
| flared port dilemma | onebadziggy | Multi-Way | 4 | 2nd January 2003 09:41 PM |
| B&W Flared Port | sianturi | Multi-Way | 10 | 11th August 2002 06:28 PM |
| Page generated in 0.08398 seconds (70.23% PHP - 29.77% MySQL) with 10 queries |
