What is "compliance" a driver or cabinet?
Old 26th November 2004, 08:36 AM   #1
andy2 is offline andy2  United States
Default What is "compliance" a driver or cabinet?
Could someone explain what "compliance" means physically?
What does it mean by "choosing a cabinet size having the same compliance as the driver"?
Old 26th November 2004, 09:04 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
In a nutshell, compliance is the stiffness. If a speaker has a compliance of 100 litres, then 100 litres of air will have the same stiffness when it is tried to be compressed.
You do not need to make the box size the same size as the driver compliance, that's ancient speaker design before they properly knew what they were doing.
Old 26th November 2004, 09:30 AM   #3
EngelholmAudio is offline EngelholmAudio
Send a message via ICQ to EngelholmAudio
If you think of a bicycle pump. Put your finger over the mouthpiece and try to press the pump toghether. There it is. Complience.
If the enclused volume would have been larger - what would have happened? Well, it would have been easier to press it toghether. Less stiff.
Same for speakers. A speaker with lage Vas is the same as a bicycle pump with large volume. Not very stiff.
OK?
best regards Engelholm Audio
www.engelholmaudio.com
Old 26th November 2004, 03:37 PM   #4
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Compliance is a technical term, still in use for technical papers.
You might see the compliance of the driver still listed in some places, with numbers like"1145MN-1" The minus 1 is in superscript. .
However, that is super technical talk. To bring it down to more useful terminology, "compliance" of a loudspeaker driver, while still listed in some places, has been replaced by the term "Vas". That is what you use for useful calculations.
Compliance of the box had been replaced by the term "Vb", or box volume. Their ratio, which you will see often, is given as "Vas/Vb".
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 26th November 2004, 04:40 PM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
Compliance is the inverse of stiffness. Compliance is in units of distance / force and stiffness is in units of force / distance.
If you have a volume of air that is being compressed by a piston it acts somewhat like a spring and teh force required to move it a certain distance is the stiffness of that volume of air, and the inverse of that number is the compliance.....
Vas is the volume of air that when compressed by a piston of the same diameter as the cone, would offer the same resistance as the cone does in free air.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
What is "compliance" a driver or cabinet?Hide this!Advertise here!
Recommend 8" Driver for Aperiodic Cabinet konut Subwoofers 4 17th September 2008 11:16 AM
Looking for Best driver for 5lt/.18 cu" front vent cabinet mr_macgee Full Range 16 1st February 2008 03:36 PM
Optimum cabinet for 3" Hi-Vi B3S single driver MrDodo Full Range 11 7th September 2005 04:57 AM
HT: scale 10" sub cabinet for 12" driver? bbaker6212 Multi-Way 9 8th May 2003 06:54 PM
Copyright ©1999-2017 diyAudio
