Question about Qtc and sealed woofer box sizes
Designing some MTMs using these 6.5" woofers. I'm trying to build the cheapest 5 speaker setup I can with the speakers I have on-hand. Should be fun!
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=299-493
Plugging the info into WinISD I get these figures for a sealed design. This info is for 1 woofer:
Qtc = 0.71 1.2 cubic ft (34.4 liters) F3= 56hz F6= 42.5hz F10= 32hz
Qtc = 0.8 0.75 cubic ft (21.2 liters) F3= 57hz F6= 45hz F10= 35hz
Qtc = 0.9 0.5 cubic ft (14.2 liters) F3= 59hz F6= 49hz F10= 39hz
Qtc = 0.98 0.4 cubic ft (11.3 liters) F3= 61hz F6= 51hz F10= 41hz
These speakers will be used 100% for Home Theater and will be using a sub with them. As you can see, these drivers require a lot of air space in a sealed box to achieve 0.71 Qtc. Seeing how these are pretty flat down to 60hz in a much smaller box, and knowing my sub can easily go to 60hz and integrate well, will the higher Qtc make the bass sound extremely "boomy"? At what Qtc should one stop? Note, these will probably never play music so they don't have to sound exceptional but I'd like for them to perform well in the HT environment. Also, I'd like to use them for the center and surrounds so making those cabinets small is pretty much a necessity. I got them for a good deal and would like to use them so please don't discourage me :D
Lastly, would you recommend doing an MTM or going with a TMM with the tweeter up top? Would that cause too much separation? I was leaning toward using either some cheap Dayton 3/4" tweeters I won or possibly getting the Dayton PT2 ribbon tweeters and seeing how I like them. Or could you guys recommend nice CHEAP tweeters that would integrate well with these? Here are the tweeters I won:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=275-030
I will be powering the whole set off modified full-range Audiosource plate amps ($25 each) that were tested at 125w @4ohms 0.1%. Using dual Shiva sonotubes tuned to 20hz. each with 300w plate amps that I purchased for $110 with shipping. I'm trying to keep the whole project under $500. I'd like for people to come over, hear it, be blown away, and then collapse of a heart attack when I tell them I built the whole thing for under $500 :D
Sorry for the long post and I'm truly grateful for any help you guys can provide. I ask a ton of questions here, I know, but I am learning. I've built only a few of the projects I've inquired about but you have my word I'll be doing this one!
THANKS! :)
The Qtc in and of itself matters little, it's what the box does within the passband. If you want to use an 80 Hz crossover, for instance, then model the driver and see what the smallest box is that doesn't give a response bump near 80 Hz or higher and also gives the flattest possible response to 80 Hz. If you get a bump at 60 Hz it won't matter much if the crossover is adequate to filter it out anyway. With 6.5s I'd cross from 80 to 100Hz so that you don't have excursion issues. As for TMM versus MTM the MTM will almost always sound better. Decide on the tweeter by seeing at what frequency the midbass is down 6dB at 30 degrees off-axis, and don't cross over higher than that. Typically that's around 2.5-3.5 kHz with 6.5s, too low for the average 3/4 tweeter, but just as well as the 6.5s in an MTM wouldn't work well to the 5 kHz minimum that most 3/4 domes require.
I have these (infinity buyout 7" with the siver trim ring) woofers in a 24liter box and they do not sound boomy at all - actually they sound fairly lean to my tastes...I wish I had gone smaller I don't think that a Q of 0.9-1 will sound boomy, especially not if you are using a sub crossover. The lower box volume also increases power handling.
The lower box volume also requires more power to reach maximum excursion or, say the same excursion in a larger box.
Depending on crossovers used, you may want a bump at the xo point. You can always make a test box of the largest volume then add pieces of wood in which to bring the volume down to the next level. Then, see if you like the sound. Measuring will also help you determine which one is 'best'. It may be tedious, but by the time you are done; you know that you have the best sound you can get within the requirements that you have set.
diyAudio Moderator Emeritus
Joined 2001
It should interest you to know that back in the fifties, when sealed design was finally completely understood, loudspeaker designers aimed their designs for a final Qtc between 0.7 and 1.0.
Qtc = 1.0 was considered something of a compromise for bass freaks, but it was still considered an acceptable design. For a home theater setup, it is hard to imagine that it would be unsatisfactory.
Note that a Qtc = 1.0 is still going to have transient response MUCH cleaner than any ported design you will ever see. Yet ported designs are in common use in high fi systems, let alone home theater.
Bottom line: go with it.
Please note posts #31 and #33 here, and click on the thumbnails:
http://www.diyaudio.com/forums/showthread.php?postid=366547#post366547
As you can see, the sealed box of Qtc = 1.0 is very much closer to Qtc = 0.7 than any practical ported alignment can get. Yet ported alignments sound good to most people. So the Qtc = 1.0 should serve you well.
Thanks so much for all the replies! Really helps me a lot!
Any chance you can let me know which tweeter you paired with these and where you crossed them over, and what order?
Thanks!
MTM vs MMT
MTM usually better for HT, because room interaction is less noticeable. Also both woofers are close to tweeter, which is nice... important to get the tweeter and woofers REAL close to each other, offset tweet to side, not completely, but a bit, or cut flanges if you are brave enough...
I dislike them for music... it seems as if the music gets letterboxed... but that may be because too high X-over frequency... But this is actually good for HT...
Thanks for all the info! Looks like I'm going to be going with a 0.9-1.0 box, after testing them of course.
Now what I would like to know is if there are any good tweeters on clearance anywhere, 1" a must, that would mate well with two of these Vifas in an MTM? I'd like to keep the cost per tweeter under $15. I was considering trying the Dayton ribbon tweeter just because I've never really designed a speaker with such a tweeter and thought it would be interesting. Not sure if it would be wise because the CtC spacing for the woofers would be increased. One thing I did like about the ribbon is the higher sensitivity and higher output it has. I was even considering trying out an MMTMM 2-way sealed. Toughts?
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=275-085
As always, you guys rock! Thanks!
I'm not too sure about MTM design principles, but I know that the MTM design will control vertical dispersion so as to kill off reflections from the floor and ceiling. This may have been already mentioned.
Anyway, I think ribbon tweets have a rectangular dispersion pattern and so may not need the MTM design. You may be better off if you go with a TMM 2.5-way design.
"Anyway, I think ribbon tweets have a rectangular dispersion pattern and so may not need the MTM design. You may be better off if you go with a TMM 2.5-way design."
Actually a MTM with a ribbon makes mucho sense since this means a less abrubt change in vertical dispersion from Fc and up.
A dome tweeter makes more sense with a MMT 2.5 way.
/Peter
How about these?
If you don't mind having a four ohm tweeter, the shielded 1" units available from ApexJr. are great. They are very efficient, smooth, and the price is awesome at $15 per pair. I ended up padding them down 3dB in my MMT which uses Peerless 850122's in parallel (straight two way). It's the third item down on the page. I'm using a 3rd order electrical filter at 2.8 kHz.
http://www.apexjr.com/speakerstuff.html
Aaron Gilbert
driver dispersion
This is a bit of a long one... I get impression you want to decide if tweet will beam and when mids will beam etc... I'm HOPING I'm not saying stuff you know - here goes - sorry if I do. :cannotbe:
but maybe somebody finds it worthwhile
wavelength = speed of sound * period.
Period = 1/freq.....
wavelength(m) = 344(m/s) / freq(Hz)
Beaming / limited dispersion increases as the wavelength of the reproduced sound approaches a specific dimension of the driver... so beaming for ribbon is usually much less in horizontal plane than vertical plane... (Because it is taller than wide) It can be said that beaming is complete when wavelength is smaller or equal to driver dimension... therefore you need to be fully on-axis or get decreased spl. With a "long" ribbon the entire length is beaming - so it beams vertically at lower frequencies but the "beam" is taller. The wide horizontal dispersion of ribbon is very cool for soundstage if you have smooth of-axis sound...
so for most MTM/line source speakers, sitting on-axis (vertically) is very important. That's one reason why long line sources need to be so long.... you're never of-axis (of course there are other benefits too...)
If a mid runs up to above 2000Hz - 7inches wavelength - the driver will beam. This is a bit academic seeing that, if the drivers are exponential cones they will, at high frequencies, move more in centre than at edges thereby making the driver diameter apear smaller... and not beam until higher... if this is done well, you won't hear it as cone breakup... Still the diameter wavelength is good rule, but you might get away with a bit higher...
... if the two drivers are further apart than 7inches ;) - centre to centre 2000 Hz is where they will start to act as separate sources, in other words interfere with each other when playing the same sound. Say you have them 11" apart (as mine are) they will start to act as separate sources at 1230 Hz. This interference will result in nulls and peaks at various distances from the speaker... so you might fiddle with speaker placement and the X-O and not hear it at all.... Also for HT this interference is often not noticable.
Now you add tweeter... that definitely does not beam at X-O so it has very wide dispersion.... And this is where I don't practically know what must be done except to try to keep the tweet close enough ctc to both drivers so that they act as one... if they are in phase. And keep the baffle as narrow and as smooth as possible -big rounded edges if possible. If you have second or fourth order X-O you can swop polarity... the interference can often be subdued this way, so try to see what sounds best...
When selecting tweet, try get one that has natural roll-off where mids are rolling off... or where you want X-O - this makes X-O easier...
So don't worry, there will be some beaming - these are the reasons why, try and minimize it through tight grouping, and play with X-O and speaker placement.
I've only heard excellent ribbons... and can't afford them but would really like to... So don't know how inexpensive ones sound. But have to think their good points would probably show up the mids in a serious way, bad ones you'd have to hide...
Enjoy
