Old 24th November 2004, 05:48 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Aren't 4th order LR crossovers supposed to pass squarewaves?
Here's my problem: I'm working on an active crossover project, and have just tested the LR4 alignment.
I thought that LR4 were supposed to pass squarewaves correctly (the summed output should be a squarewave), but mine doesn't
What's wrong?
Here's the (simplified) topology.
I think it's a LR4 alignment, since Q of one stage is 1/(3-Gain) and gain=1.58. Q=0.707 (butterworth)
2 cascaded 2nd order butterworth form a LR4
http://www.diyaudio.com/forums/attac...amp=1101235143
input signal (red), the low pass output (green) and high pass output (blue)
http://www.diyaudio.com/forums/attac...amp=1101234956
And here's the summed output
http://www.diyaudio.com/forums/attac...amp=1101235302
Thanks for help
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 24th November 2004, 05:50 PM   #2
SY's Avatar
I don't think that's true.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 24th November 2004, 05:50 PM   #3
pxr5 is offline pxr5  United Kingdom
you output will look nothing like a square wave.
Old 24th November 2004, 05:53 PM   #4
from memory i think its only summed 1st order which will. google search and some typical results will be found
Old 24th November 2004, 05:55 PM   #5
also this is 1st order INCLUDING speaker driver transfer function, generally the higher the order the less like a square wave
Old 24th November 2004, 05:56 PM   #6
Henrik Juhl's Avatar
Default Not square.
Bricolo,
Neither do I think the throughput should be square
Have you seen this article about 'transient perfect' filters?
http://www.geocities.com/kreskovs/CrossoverdocN.html
See also his main page on: http://www.geocities.com/kreskovs/John1.html
Some foods for thought and very inspiring.
Henrik Juhl
Old 24th November 2004, 06:04 PM   #7
I'm am misconceived
Old 24th November 2004, 06:05 PM   #8
Davey is offline Davey  United States
Default Re: Aren't 4th order LR crossovers supposed to pass squarewaves?
Originally posted by Bricolo
What's wrong?
Nothing. Your simulation results look correct to me. LR4 crossovers, as well as many other, won't sum and reproduce a square wave identical to the input. This is normal.
Davey.
Old 24th November 2004, 06:28 PM   #9
Bricolo's Avatar
OK, thank you guys. I was mistaken...
Old 24th November 2004, 06:53 PM   #10
hifi is offline hifi  Sweden
bessel are suppose to pass square waves pretty well since they feature a flat groupdelay in the passband so not to delay any of the squares harmonics.
Phase Reversal in 2nd Order Crossovers BlueWizard Multi-Way 69 12th July 2007 04:27 PM
Any reasons not to go 4th order LW when going all active crossovers? MarkB1 Multi-Way 1 14th March 2005 07:16 AM
Higher order crossovers is it possible with LM4780? diysmartdeep21 Chip Amps 0 10th February 2005 12:17 PM
Aren't gold plated connectors supposed to be inoxidable? Bricolo Parts 31 28th November 2003 02:19 AM
Looking for DIY Kit with First Order Crossovers alex douglass Multi-Way 2 13th November 2001 06:06 AM
Page generated in 0.11890 seconds (72.35% PHP - 27.65% MySQL) with 11 queries
