Old 25th November 2004, 05:29 PM   #11
5th element's Avatar
Cherry is a good hardwood to use, its closed grain so makes for easy finishing, looks good and is REALLY easy to rout, with no splinters that break off etc. Although it is susceptable to burning when used with power tools, however the burn easily sands away.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 29th November 2004, 06:56 AM   #12
jamesj is offline jamesj  New Zealand
The problem with using natural wood is its tendency for movement with humidity changes. Some species will move more than others. Then, the manner in which they are sawn will dictate the direction in which movement will take place. It is best to use kiln-dried, quarter-sawn timber for this application.
My favourite specie is Sapele, which I have used to clad four DIY designs to date. Black American Walnut is also very good, but difficult to match for jointing purposes.
HTH.
James
Old 29th November 2004, 10:38 PM   #13
With wood moving due to humidity, its important to make sure that all sides are pretty much equal in their exposure to the outside.
If one side of the wood is exposed to the air and other side side is finished with an air tight polish, then the water in the wood will evapourate faster thru the unfinished side, or absorb water. This WILL cause the wood to warp and loose its shape.
If on the other hand you have clad a speaker with wood the inside of the wood is exposed to MDF which is going to prevent water loss. And then the outside of the wood (which you see) will have a watertight finish on it, so will either completely stop, or greatly reduce water loss. This way the wood stays stable and it should stay in shape.
Old 29th November 2004, 11:09 PM   #14
Brett's Avatar
If I was going to build a baffle out of Aussie woods, I'd use Tassie Blackwood. Luvverly.
But if I could afford it, I'd use Wenge or Cocobolo. Or Pau Ferro.
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
open baffle Mr Hayes Multi-Way 3 14th May 2004 03:05 AM
Page generated in 0.08799 seconds (73.18% PHP - 26.82% MySQL) with 10 queries
