Australians- what solid timbers for baffle? (open baffle loudspeaker)
Old 24th November 2004, 12:13 AM   #1
tktran is offline tktran  Australia
Account Disabled
Default Australians- what solid timbers for baffle? (open baffle loudspeaker)
I'm building the John K NaO, an open baffle dipole loudspeaker.
John uses a 19mm oak baffle in his prototype, and then solid concrete in a 2nd version.
I wonder if anyone has experience with different hardwoods in loudspeaker building. Depending on who I ask, it's bit of a no-go in building box loudspeakers, but I wonder if the same applies to open baffle speakers.
Tassie oak? Jarrah?
Old 24th November 2004, 12:16 AM   #2
chris ma is offline chris ma  Canada
chris ma's Avatar
Default Re: Australians- what solid timbers for baffle? (open baffle loudspeaker)
Tassie oak? Jarrah?
I have heard of there is a kind of tree in your part of the world named HUON. I wonder are those suitable for your project?
The Butcher
Old 24th November 2004, 01:31 AM   #3
David Gatti is offline David Gatti  Australia
David Gatti's Avatar
I used Jarrah hardwood on the corners and baffle of my "Vespa" speaker project. Sourced it from Bunnings floorboard supplies - extemely hard and stable timber which I have had no problems with over the last 15 years.
http://www.gattiweb.com/vespa.html
Old 24th November 2004, 01:43 AM   #4
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
With OB, use whatever you like. Even wood that had some kind of interesting knots and holes would work. The baffle stores so little energy and doesn't have pressures pushing on it other than the operation of the driver itself, which is why Linkwitz recommends attaching the drivers with a support at the magnet.
Everyone has a photographic memory. It's just that most are out of film.
Old 24th November 2004, 04:36 AM   #5
HiFiNutNut is offline HiFiNutNut  Australia
tktran,
Mine is being built. Initially I wanted to do it myself. I simply didn't have the experience to use a router to trim the edge of the speaker holes to flush mount the drivers, and I couldn't find a carpeter who was happy to do such a small job. Fortunately, I found somebody who were happy to build the whole speaker for me for under $AUD450 including materials and labour OR possibly $650 painted. I gave him the job straight away. It is now 70% completed. He bought some American oak and used thick high quality MDF. The workmanship is not first class but is quite acceptable and I am happy with it. But what do you expect for a few hundred dollars? If you want this guy to build it for you I can give you his contact. It is a bargain even if you include the shipment fee from Sydney to Perth.
Best regards,
Bill
Old 24th November 2004, 05:47 AM   #6
noodle_snacks is offline noodle_snacks  Australia
Send a message via MSN to noodle_snacks
Chris, Houn pine looks really nice and is quite expensive but is actually not particularly rigid or strong as it is a softwood.
Old 24th November 2004, 06:05 AM   #7
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
I saw some Jarrah in bunnings and as soon as I saw it I was trying to think of a speaker project I could use it for! The idea of an open baffle with hardwood does appeal to me.
I would use approx 19mm thick hardwood, double thickness around the edges and have a fairly large radius on the edges. I would also attach MDF to the rear to make it more solid. 3/4" would just look too think IMO.
Here's a nice example for inspiration
You could also just use veneer as shown here with this example which still uses curves (in one dimension):
curved veneer dipole
Old 24th November 2004, 06:47 AM   #8
oldbar is offline oldbar  Australia
I am doing my first speaker project and rebuilding some old optimus boxes which to my suprise the mdf was 18mm and i am putting a second layer of mdf for my baffle.I have not done anything with wood for years and this was a good project to start with .
I bought the jasper jig for my holes and it works great made cutting the holes a breeze I am near Foster so buying parts are all mail order for me .I am finding the crossover a hard one to try to work out but i am going to keep at it.
Old 24th November 2004, 11:26 AM   #9
Jonathan Bright is offline Jonathan Bright  Australia
In 1997 I was labouring on a bilding site in the Victorian alps (Mt Hotham) and they were using a couple of very hard woods for an external walkway. The only one I remember is called "Tallow wood" ( I think), weighs a ton (dense) and must be very durable as it was in extreme conditions (under snow for 4-5months a year) in a high use area. So if you want rigidity that may be an idea.
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 25th November 2004, 04:45 PM   #10
Account Disabled
Thank you all for the suggestions.
Hifinut,
Thanks for the offer, but I'm going to give his one a go myself.
Australians- what solid timbers for baffle? (open baffle loudspeaker)Hide this!Advertise here!
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
open baffle Mr Hayes Multi-Way 3 14th May 2004 03:05 AM
