This question is related to a horn but I think it applies to all speakers.
At the low cutoff of my horn the FR plot shows a peak in response, however, the impedance spikes at this same point. What is the real outcome of this? Does the peak in response actually get negated because the amplifier can't deliver the same power due to the increase impedance?
Everyone has a photographic memory. It's just that most are out of film. |
#2 |
Is the peak at/around driver FS?
Impedance will rise as the frequency approches FS, where it is most resistive. I'm not a horn guy, but the driver's increased efficiency at FS, coupled with the horn must have something to do with your spike in SPL. Typically you won't see that in any boxed alignment. |
#3 |
Banned
The impedance spike is normal at the horn fc; it's one way of knowing where the fc is. It has nothing to do with the driver fs per se. There will also be a peak at the rear chamber fb, unless the horn is perfectly reactance annulled, in which case the fb and fc are identical and there is only one peak.
#4 | |
#5 |
Banned
The amp will be just fine. The spike also coincides with where the system operates most efficiently. Reponse will fall off below fc at 12dB/octave from the horn component, and another 12dB per octave kicks in below fb of the rear chamber.
#6 |
I guess I did it right. Only 1 spike in impedance and the rolloff below 40hz looks more like 24db per octave. Thanks for the help.
| Impedance phase plots - 4 ohm drivers | fb | Multi-Way | 1 | 17th August 2008 08:07 AM |
| Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? | rhythmdiy | Multi-Way | 5 | 5th November 2007 11:33 AM |
| Need help with impedance curves and FR plots... | fjhuerta | Multi-Way | 13 | 8th April 2006 08:57 AM |
| Impedance Phase Plots | kelticwizard | Multi-Way | 13 | 28th February 2004 06:28 PM |
| Impedance / sensitivity | Steen | Multi-Way | 2 | 5th September 2001 05:53 PM |
| Page generated in 0.09727 seconds (72.23% PHP - 27.77% MySQL) with 10 queries |
