In a rear horn I understand that it's important to have the horn's output and the driver's output in phase at their cutoff frequency to avoid cancellation at that acoustical crossover point.
My question is how do you go about choosing that point? Should you look at the driver's free air response and where it starts to decline, have the horn take over? OR Should you look at a drivers response in a sealed box the size of your compression chamber and make the point where the driver is say 3db down your horn cutoff point?
Everyone has a photographic memory. It's just that most are out of film. |
#2 |
try transmission line google search,
1/4 wavelength |
| Smallish rear back horn design? | suposs | Full Range | 21 | 14th May 2009 07:28 PM |
| How to design folds in rear loaded bass horn | tstt9000 | Multi-Way | 3 | 26th August 2007 03:59 PM |
| My first front and rear horn loaded fullrange design: help needed from The Wise. | maxlorenz | Full Range | 20 | 11th July 2007 10:21 PM |
| Horn design parameter question | heijnsva | Multi-Way | 10 | 16th March 2006 10:19 PM |
| rear loaded horn question | zobsky | Multi-Way | 5 | 21st September 2004 08:13 PM |
| Page generated in 0.07209 seconds (66.49% PHP - 33.51% MySQL) with 10 queries |
