Old 22nd November 2004, 06:46 AM   #1
bigerik is offline bigerik  Canada
Default What to build in a Dynaco A-10 Cabinet?
Hi All
Recently came across a pair of Dynaco A-10's. Brought them home for a listen and found them to be decent, if uninspiring. Did a little reading and found that Morel made a tweeter (forget the number now) which is a direct drop in for it. Then I started wondering about replacing the woofer too. Just a 6.5 inch woofer.
Anyone ever built anything into these cabinets? Nice simple classic cabinets. I can do speaker building, but I have no where to build cabinets. Any thoughts?
Erik
Old 22nd November 2004, 05:10 PM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: What to build in a Dynaco A-10 Cabinet?
Besides tweaking things -- that metal grill coming off the tweeter makes a big difference, replaceing the caps in the XO, tweaking the woofer, and routing off the big lip on the baffle -- all the alnico drivers & XO are worth something on eBay (one of my workbenchs is made of A25 carcasses, and the stand under one of my wife's shelves is made from A10s.
If i was rebuilding, i'd probably be thinking of putting the drivers in a new box & turfing the older box instead of the other way around.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd November 2004, 06:44 PM   #3
mercator's Avatar
So Dave,
Sorry for the thread-jack here but you have piqued my interest.
I have a pair of A-25s in the basement. Any recommendations on what sort of box would suit those drivers?
Thank you for your patience, we now return to the discussion on A-10's.
/Dave
Experience is what you get when you don't get what you want.
Old 22nd November 2004, 07:09 PM   #4
frugal-phile(tm)
planet10's Avatar
All the same mods work... figuring out what tweeter level works best & replacing the switch, cheap sand resistors & eleco cap would be the XO mod.
The same box, but done up in ply, braced with no sharp edges would be a 1st round... actually measuring the T/S and seeing if a T-Line would work would be 2nd.
http://www.t-linespeakers.org/classics/dynaco.html
dave
Old 25th November 2004, 03:22 AM   #5
Thanks Dave
Looking now at starting from scratch. Started working the woofers in the A-10's, and there is a lot of flex in those cabinets. Just does not make much sense at all.....
Thanks!
Erik
Old 25th November 2004, 02:47 PM   #6
Thumbs up Dynaco / Scanspeak ? A10's ?
Hi folks,
I just bought a pair of Dynaco A10's That are in pristine condition, and the sound fantastic? I notice they are mirror imaged tweeters never saw a pair like these......I am guess ing thes are very early models with Scanspeak drivers?
Does anyone know more about these? I have looked around the web, but can find no info, I am interested in the crossover design details.
Thanks!
Old 25th November 2004, 04:02 PM   #7
frugal-phile(tm)
planet10's Avatar
I haven't made a map yet...
dave
Old 12th July 2005, 10:26 AM   #8
Dear Mr . Planet10
How is the progress ?
I really need schematic of Dynaco 35A's crossover.
Anyway, Tks u very much.
Old 12th July 2005, 05:37 PM   #9
frugal-phile(tm)
planet10's Avatar
That is what you call syncronycity... i just posted the A50 XO last night -- the A35 (and A25) XO is simply the tweeter part of the XO -- althou i strongly suspect that A25.A35 could be improved by adding the woofer low pass.
From My Dynaco Page
And i did a set of impedance measures for the effect of the tweeter levels (attached)
dave
BTW... the XO i traced this from will be amongst my eBay auctions late this week.
Old 13th July 2005, 10:33 AM   #10
Noted your infor with many thanks !
I ' ve bought a pair of DYNACO speaker.
At the behind side of speaker , I saw that a mark : Scandyna A30. As u know, Dynaco A25 has got Aperiodic Port uder the woofer but in my speaker Aperiodic Port above the Tweeter.
Beside. I found these sentence in one website:
Dynaco speakers were designed using Seas drivers, and imported to the USA under the Dynaco name. Interestingly the earliest A-25's used ScanSpeak Drivers and had the Aperiodic Port above the Tweeter, but this was soon changed to the widely seen Seas Drivers and the port under the woofer.
When I look at front of speaker , It is similar to Dynaco A35 and furthermore it has Aperiodic Port above the Tweeter.
I wonder what is it model of Dynaco ???
Please advise your comment !!!
Best regard .
Anyone ever build a glass cabinet? Javachip Multi-Way 14 23rd May 2006 03:27 PM
Want to build bass cabinet for Fender BXR 300 timzog Multi-Way 14 11th June 2004 11:50 AM
Best Dynaco MKIII driver circuit for hobbiest build? jjasniew Tubes / Valves 15 31st December 2003 08:34 PM
anyone ever build a cabinet with Karlson slots? bbaker6212 Multi-Way 15 7th August 2003 03:10 AM
Page generated in 0.14226 seconds (79.87% PHP - 20.13% MySQL) with 11 queries
