The Madisound board seema clueless about these drivers, so I'm asking here: I'm looking for any experience with any of these neodym 25mm dome Seas tweeters:
http://www.seas.no/seas_line/tweeters/H614.PDF http://www.seas.no/seas_line/tweeters/H623.PDF http://www.seas.no/seas_line/tweeters/H615.PDF http://www.seas.no/seas_line/tweeters/H625.PDF I believe they will sound alike, apart from some glitched due to the faceplate dimensions. The motor seems to be the same for all four tweeters, just the faceplate and the dome material is different. These tweeters have been around for quite osme time, do I would think someone here must have heard/tried them. Thanks
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. --- Douglas Adams |
#2 |
diyAudio Editor
well, some were designed for autos which is probably why home audio people don't know much about them.
The ones with smaller housings would seem to be perfect for making coaxials out of regular woofers, by removing the dust cap and attaching them to the pole piece. |
#3 | |
I think it would be more accurate to say that in this case 'home audio people don't know much'
#4 | |
I've used the H623. It needs to be crossed over over very high and steep to avoid sounding harsh. Considering that, it's roughly about as good as any other small neo tweeter. If this is for a car, consider the LPG 26NA. I've used this and I think it's a better sounding tweeter. Same crossover issues however. 4th order acoustic at 3Khz is about the lowest I would go. If this is for home usage, consider the Peerless 811435. It's impressively smooth with low distortion. Better than the rest of Peerless' crappy tweeters too, if you can believe that. And then of course consider the small flange Morels.
-Zaph|Audio- |
#5 |
Out of all those tweets id go for the second on the list, the H623.
All of them seem to be pretty much identical with regards to power handling, resonance frequency, xmax. Obviously the faceplates are different. But all the tweeters seem to have pronounced ridges in the waterfall plots and in sensative areas too, at about 2k. The 623 doesnt have any off these so for that reason alone I would pick the 623. Dont cross too low with these either. Although the resonance is really well damped I wouldnt go below 3khz with steep slopes. You would need a driver with a pretty large voice coil to mount them coaxially, 47mm voice coil probably and thats cutting it rather close. Plastic faceplates will make sculpting easy, but you wont be able to reduce the diameter anymore then then 45.9mm, but you will be able to remove the square bits on the non circular ones. Infact I cant find any driver you could mount these on, in the middle of the voice coil. The only ones are the peerless XLS and some other large drivers not suitable for midrange application. The only company that springs to mind is dynaudio, but in that case you would not want to damage the driver and probably partner it with a better quality tweeter.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#6 |
diyAudio Editor
I think Morel makes some smaller drivers with 75mm voicecoils -which look a lot like the Dynaudios! These were used in the Eggleston speakers I believe. Since the tweeters are only about 50mm, that allows a bit of tapering of the piece that holds the tweeter, like a phase plug. Too bad they really don't seem to be top of the line..
#7 | |
#8 | ||
I'm currently experimenting with modifying the frontplate of a couple of Vifa XT19's, also a version with a short horn in it... if that doesn't work out, I will need a high value and quality alternative with a small faceplate. The Peerless you mentioned could be it. Thanks!
#9 | |
I would personally just prefer to buy the TPX/PP 6.5" seas coax unit, it would probably come out cheaper (those morels are not cheap) and are guaranteed to work. However if you like a challenge and this is more to do with you wanting to have a go, then by all means go for it.
#10 |
diyAudio Editor
Actually I meant that the tweeters weren't top of the line.
I agree that this project would be for those of the experimental sort. I am mighty tempted by the Seas Coax- you have me figured out there!BUT I'm wondering if having the tweeter extended a few inches out from the polepiece might sound better than using the big cone to kind of horn load the tweeter as in the Seas Coax. |
| WTS: 3x Morel MDT 12 1 1/8" Neodymium Tweeters | speaker | Swap Meet | 13 | 15th May 2007 03:44 PM |
| Seas Millenium tweeters and Seas W22EX-001 | sephiroth619 | Swap Meet | 2 | 5th March 2007 06:34 AM |
| new Seas Nd tweeters to be shown at CES | capslock | Multi-Way | 0 | 4th January 2006 11:19 AM |
| seas tweeters.......need help | ermes | Multi-Way | 2 | 21st June 2004 04:48 PM |
| New Seas Tweeters | ANTHONY2181 | Multi-Way | 0 | 15th August 2002 04:47 PM |
| Page generated in 0.14276 seconds (82.99% PHP - 17.01% MySQL) with 11 queries |
