Starting piont: A pair af Rega Kyte with blown tweeters
The tweeter in a Rega Kyte is a modified Vifa D20TD-05-06 The modification is an resonant chamber which loweres the resonanse frequency. Actually this is the second time I experience blown tweeters in a Rega Kytes - so I was looking for something better... The Vifa XT19TD00-04 has the same sensitivity as the D20TD-05-06 and by the way the same diemnsions So I though that I could try just to replace the tweeters with the XT19 and thereafter modify the X-over if needed. Listening/Conclusion:
Regards, Ask |
#2 |
I have a pair of Rega Alyas which use the exact same drivers as the Kyte. I like their sound but on the other hand I always wanted to try the "nippled" XT19, just couldn't find any designs that used it. I gotta try this...
#3 | |
#4 | |
When powered with qualified electronics the result is definitively high-end, the tweeter has been made to perfectly match the highly praised Rega designed midbass driver for the exceptional midrange performance Rega speakers are famous for. My idea is to try the X19's diaphragm on the Rega modified D20 rather than simply replacing the tweeters as I feel a simple swap could affect time alignment built into the Rega crossover since a ferrofluid cooled system would likely experience further delay in response. I was pleased to see that the X19 is still available even though it is now sold under the Peerless Vline brand rather than Vifa. No idea why Tymphany enjoys confusing us to such an extent. |
#5 | |
#6 | |
#7 | |
I'll add that you cannot use the XT19 dome on any other motor. The mounting mechanism is intended for and glued to the pole-piece vent that is significantly different in dimensions. There may also be a difference in voice coil gap in the motor. Removing the diaphragm will likely damage it irreversibly. Use the XT19 and change the crossover. Dave |
#8 | |
#9 | |
It's also one of the rare speakers that are practically WAF-proof because of their small footprint and conservative-yet-elegant genuine cherry veneer finish on all sides and slightly rounded edges. I was even allowed to leave them without their grills
| Seas 27TBFCG or Vifa XT19 | AdamZuf | Multi-Way | 9 | 22nd April 2009 09:13 PM |
| I'm looking for measurement of XT19 # | el_liero | Everything Else | 2 | 6th December 2007 10:56 PM |
| Vifa XT19 or Dayton RS28 tweeter? | silvercans | Multi-Way | 2 | 8th November 2005 04:11 AM |
| Bottom end for XT19/XBL^2 4"/ 3 way | dunderchief | Multi-Way | 3 | 4th October 2004 11:06 PM |
| Xt19 | flux01 | Multi-Way | 2 | 24th July 2004 04:03 AM |
| Page generated in 0.12893 seconds (83.22% PHP - 16.78% MySQL) with 11 queries |
