Hello;
I am new to designing speaker boxes, so these are probably a simple questions. Given a calculated ported box volume with a round port: Do you calculate the volume of the port to convert to a shelf port.? As the shelf would be full internal width would it still be tuned? What is the minimum distance from the back for a shelf? Is it ok to bend the shelf into an "L"? Then calculate the volume of the shelf to add to the volume of the box? If you do this it will mess up a "golden ratio" box? (I planned to make the shelf quite thick) I want to use a shelf because its essentially free, and becomes a brace too. What about angling the shelf to form a horn shape? This is for a 15" subwoofer only. Box size approx 17"W x 28"H x 10.5"D Volume 2.77 ft3 Port size 6" dia x 27.3" (two 45 deg bends, 6" to stop any whistling) Fs 18.8, Vas 319 ltrs, Qts .239 Port Fb 29.42 Hz, F3 37.86 Hz The shelf would be 2x 5/8" sandwich. I plan to use 5/8" board, then if it sounds ok double up the outsides with a sand center. So a triple sandwich of 5/8". Hopefully this should minimize internal bracing. Thanks Mick M. ( I happen to have 3 sheets of 5/8 board and the driver already) |
#2 |
You can safely ignore the need for a golden ratio box for subwoofer use, the wavelengths are too long for standing waves to occur. Concentrate instead on making the box as strong as practically possible.
Regarding the shelf port, try to keep the ratio under 10:1, really thin slit vents can alter the tuning frequency in unexpected ways and can have reduced output (as far as pure resonance is concerned a round port is superior) |
| Port question, round vs rectangular | kvk | Full Range | 6 | 11th February 2008 08:16 AM |
| 2 Woofers = 2 x Volume = What Port? | sdclc126 | Multi-Way | 21 | 16th January 2008 07:53 PM |
| Newbi: Box Volume and Port Length | 69stingray | Subwoofers | 14 | 22nd April 2005 02:57 AM |
| Need Volume And Port Size For Norh 9.0 | sardonx | Multi-Way | 0 | 1st August 2004 02:44 AM |
| Question about port volume | dveous | Multi-Way | 3 | 7th July 2004 07:24 PM |
| Page generated in 0.07900 seconds (68.18% PHP - 31.82% MySQL) with 10 queries |
