Speaker Workshop do all this? - diyAudio
Old 19th November 2004, 04:04 AM   #1
Default Speaker Workshop do all this?
Can Speaker Workshop do all of the software-measurement jobs here
http://www.diyaudio.com/forums/showt...373#post515373
- especially post 5 (speaker project plan 101)
- or would it be easier or much better with a commercial package like SoundEasy?
Old 19th November 2004, 02:26 PM   #2
jjdche is offline jjdche  United States
19 Build subs
I don't think Speaker Workshop is going to build your subs for you, but yes, it is a rather full featured piece of software.
Old 19th November 2004, 08:19 PM   #3
JMB is offline JMB  United States
Speaker Workshop has some limitations compared to SoundEasy but it is just as accurate according to several (including, I believe, John Kreskovsky). I don't believe that any of the limitations are likely to interfere with your ability to build an outstanding speaker system; it is more in the area of measurements of distortion. Along with the help and contributions of several folks, I have put together a manual to assist with the learning curve portion. There are several spreadsheets and informationals in it to ease the learning curve as well. It can be downloaded at www.audiodiycentral.com (the Manual is currently version 1.0).
Hope you try it and hope it helps,
Jay
Old 20th November 2004, 04:45 AM   #4
Hi Jay
I had a squiz at the SW manual, and with that looking quite comprehensive, I probably should give it a go, subject to:
Can Speaker Workshop handle?
- Time alignment of drivers
- (As LspCad can I believe) XO optimisation (to a curve), and
- actually give XO component values?
Old 20th November 2004, 07:17 AM   #5
Researching XO design here, I read in an old post
don't forget to account for baffle step when designing the crossover, or correct it at line level (much better)
(I know what baffle step is)
Whats meant by line level in a passive XO rather than an active XO)?
Thanks again
Old 20th November 2004, 07:20 AM   #6
paulhfx is offline paulhfx  Canada
Jay,
I would hope and expect this has been said already elsewhere, but thank you for that detailed and informative manual which was obviously a Pile of work.
Paul
Old 20th November 2004, 01:55 PM   #7
Originally posted by rick57
Hi Jay
You should download it and give it a go yourself, thats what I did. Its free, you know.
Old 20th November 2004, 02:02 PM   #8
Yes I know Speaker Workshop is free, which is great.
Im also going through though major learning curves on the woodwork & electronics, and there is only so much time in the day . .
So Id rather select the software up front, that will do *everything* needed, and just learn that one package.
If SW doesnt/ does not do those three things above, Id like to know before I start . . .
Old 20th November 2004, 02:11 PM   #9
Default satellites + separate subs
I should clarify,when say
adjust for the "Time alignment of drivers" - this is including where the drivers are in different boxes, ie satellites + separate subs .
Which software can do that?
Speaker workshop ? A_Reef_Scene Multi-Way 14 28th February 2007 12:39 AM
My Speaker Workshop Rig bigmike216 Multi-Way 0 28th November 2004 01:24 AM
Speaker Workshop: the best and how to use it? rick57 Multi-Way 12 13th August 2004 11:12 PM
Which mic for speaker workshop? azira Multi-Way 2 12th February 2004 05:12 PM
Speaker workshop Ilianh Multi-Way 2 10th January 2003 09:11 PM
Copyright 1999-2017 diyAudio
