A few quick question before glueing the back of my enclosures
Old 18th November 2004, 11:48 AM   #1
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Default A few quick question before glueing the back of my enclosures
OK, I'm hoping to be able to listen to my first DIY loudspeakers with Visaton drivers this Saturday. The boxes are glued, except the back, the holes for the drivers are cut, the crossovers are finished, all I have to do is glue the back, mount the XO board inside, mount the drivers, put the damping material, wire it and pump some amperes into them. Some last few questions that will make me finish the last steps with confidence.
1. Do you leave the wires inside loose or do you tighten them to the inside of the enclosures? I'm thinking about glueing them to the MDF with a few drops of PVAC.
2. How do you fasten the XO inside? Well, if you put it inside, which I will.
3. About the damping. My box is a 2-way, 40 liter, bass-reflex, 1m of height, approx 20x20cm cross-section. I'll use wadding as damping material at start. Generally, how loose does the damping have to be? Of course I'll experiment with the amount I'll put inside, but I want to get a raw notion of how loose or dense does it have to be inside.
4. How do you seal the woofers at the flange? I gather that silicone sealant is OK, but I'm afraid it'll get on the diaphragm.
I'm sorry if these questions sound stupid but I sometimes have difficulties figuring out simple stuff Like that suggestion someone here gave me, using a tourniquet made of rope for tightening the box when glueing. That was really useful, and I doubt I could've re-invented the method for myself.
we all love a good ol' stereotype until it's against us
Old 18th November 2004, 12:02 PM   #2
tiroth is offline tiroth  United States
No matter what you do, I hope that you close up the back /without/ glue and spend some time listening. You can use clamps if needed, but it will probably be a lot easier to alter stuffing/damping/etc if you can remove the back.
Old 18th November 2004, 12:30 PM   #3
Paul W is offline Paul W  United States
Paul W's Avatar
...same for the crossover network. You will want to tweak the xo, so make sure it is accessible without major surgery.
4-way dipoles
Old 18th November 2004, 10:57 PM   #4
David Gatti is offline David Gatti  Australia
David Gatti's Avatar
Firstly, congrats on your near project completion.
1. I would leave the wires loose, so that it's easier to install and remove the drivers.
2. I generally "glue" the crossover to the rear or bottom wall using silcon . Keep in mind you may want to remove it later.
3. Damping should be not to tight, not too loose and depends on the material used. You should ensure a clear air path from driver cone to port. Experimentation is the best idea and make sure you give the woofer time to break-in before making any further changes.
4. Seal the woofers using foam insulating tape, which is used for sealing around window frames, etc. Silicon tends to act like glue, is messy and can be hard to remove.
Good luck.
David
www.gattiweb.com
Old 18th November 2004, 11:23 PM   #5
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
[offtopic]David, just had a look at your construction pics for the Delta design. Inspiring [/offtopic]
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 19th November 2004, 04:06 AM   #6
Thanks. Progress has been slow lately, but should pick up again soon
A few quick question before glueing the back of my enclosuresHide this!Advertise here!
Glueing MDF enough? protos Multi-Way 23 24th April 2015 09:17 PM
Back loaded horn & Transmission line enclosures IG81 Full Range 1 18th December 2008 02:40 PM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Glueing tiles on the back of the cabinet? blank527 Multi-Way 4 24th February 2006 04:45 PM
just found back a quick drawn schematic of my amp hugobross Solid State 27 26th June 2003 11:29 AM
