I have had 2 sets of drivers from a friend. I hope some of you guys and Ladies (if any) can tell something about them.
2 tweeters 19mm it says on the label: Rega D2008/7203 made by Scanspeak. It also says Rega Ela. 2 Bassdrivers about 41/2" - 5" depending on where it is measured. It says on the label RR125 Rega. Papercone with phaseplug. I am not even sure they come from the same speakers. So if anyone can tell if it 4 or 8 ohm's and what boxes they come from, well all information is welcomed. I had these for soldering a chipamp for the guy! Cheap I think, considering the small amount of solder that goes into that amp Steen. First a pic of both drivers. |
#2 |
the bass:
#3 |
The last one: tweeter.
#4 |
REGA.
Roy Gandy of REGA Turntables fame also manufactures CD players and amplifiers and Loudspeakers. He used Modified drive units hence REGA part no's on OEM drive units. He hated x overs so set about designing loudspeakers where the voice coil resistance inductance etc could be used as an integral part of the x over. Hence the bespoke drive units. I personally am not a fan of his speakers but they do have some merit and have been successful. I hope this is of help. regards David
regards David |
#5 |
http://www.rega.co.uk/index2.htm
You could possibly email them directly and ask for the specs of the drivers yourself. The drivers look good though Edit: I noticed that their current line of production still uses the same midrange driver. Maybe you could do a clone project if possible. |
#6 | |
Thanks for the replies.
I thought of making some kind of "average" crossover, if I wasn't able to get some data's on the units. But if this coil is meant to be part of the x-over, that approach would, I think shoot way past the target?? I will try and email Rega about this. Steen. |
#7 |
Here is the result I achieved with these drivers
They sound quite well Steen. |
| Page generated in 0.09551 seconds (75.35% PHP - 24.65% MySQL) with 10 queries |
