Dear All.
I need a formula telling me what the sound pressure level is at a certian distance from a source given that the spl of the source is known and that the distance is known. I know it is a "universal" formula - but are looking for the simplest form, where walls or other reflecting source are not taken into account. I tried a google search, but no luck so far. A search here in the forum didn´t help me either. Anyone? Please :-) Thanks in advance Regards Hans-Henning
If you cannot measure it - you cannot improve it! |
#2 |
What kind of source? Piston, point source, line source, simple or dipole, etc...?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
Point source -6dB for every doubling of distance
Line source -3dB for every doubling of distance This is for ideal monopole sources. /Peter |
#4 |
Excellent. Thank you.
Case closed Regs. Hans-Henning
#5 |
Banned
Not so fast. Line sources are -3dB per distance doubling only within the nearfield, which is calculated (in meters) by the formula R=L x L x f/700 where R is the distance to the nearfield/ farfield transition, L is the array height and f is the frequency. Once in the farfield the 6dB rule applies.
#6 |
Bill, are you really sure that formula is correct? Feet or meters?
Say 100Hz/700 = 0.14 Line height 2.4 meter 0.14 x 2.4 x 2.4 = 0.8 meter. That would mean that farfield for 100Hz begins at 0.8 meter. 20.000Hz/700 = 28.57 28.57 x 2.4 x 2.4 = 164 meter transition for 20k. Maybe it´s 700/f ? /Peter |
#7 | |
#8 |
There is no such thing as a true line source, so why even bring it up unless you are writing a text book on theory?
Also, the line array effect doesn't change from the 3db decrease to 6db at a finite point, it is a gradual change. Therefore what is needed are both forumlas, where the transition point starts and where it ends, in order to get a good picture of how the array will behave in the real world.
Everyone has a photographic memory. It's just that most are out of film. |
#9 |
No worries!
Concept of theory and pracsis are not the issue :-) you guys are discussing weather infinite does exist or not. The answer depends on what glasses you´re wearing - eg. a mathematicians or a phycisists... Or more "earthnear" weather the universe has a boundary or not! - Try cracking that one :-) In fact - a sound from any source will never never ever die completely - but it will decrease (in audiolevel), and during the decrease an energy conversion will take place... I got the answer i needed - point of source is the issue in this case, so the -6dB is the case. Thanks again :-) Regs. Hans-Henning Ps: and sorry for my bad english.
#10 |
Banned
A 'true' line source with no farfield doesn't exist; can we agree to limit discussion to real-world circumstance?
Yes, a 2.4 meter array will go from near to farfield .8 meters from the radiating plane. The same array goes to farfield at 82 meters at 10kHz. In pro-sound where line arrays today dominate it's generally accepted that trying to go lower than 80 Hz in the nearfield is not a worthwhile endeavor. The change from nearfield to far field is actually a fairly abrupt transition. |
| DIY loudspeaker vs. factory built loudspeaker | keyser | Multi-Way | 83 | 16th May 2011 01:27 PM |
| Q formula | PeteMcK | Multi-Way | 10 | 17th January 2008 08:42 PM |
| Loudspeaker Filter Formula's | Lars Clausen | Multi-Way | 11 | 19th November 2003 05:22 AM |
| Need help on x-over formula | Jay | Multi-Way | 3 | 12th August 2003 06:28 PM |
| Anyone have the formula for... | Rino odorico | Multi-Way | 4 | 22nd January 2003 05:07 PM |
| Page generated in 0.11337 seconds (79.73% PHP - 20.27% MySQL) with 10 queries |
