Old 18th November 2004, 01:30 PM   #11
Pan is offline Pan  Sweden
But sure prosound use with (normally) no ceiling, and home use where the line can be a "true" linesource is two different situations, no?
I have not done my homework on linesource theory, though I understand the basics so so.
/Peter
Old 18th November 2004, 02:02 PM   #12
Banned
There are similarities. Consider a live sound venue where the required throw is 100 meters. To reach that at 80 Hz in the nearfield would require an array height of about 30 meters. That's not practical in most cases.
In a home with a throw of five meters getting to 80Hz in the nearfield requires an array almost 7 meters high, also not a viable option. But realistically it doesn't matter, as once the frequency is low enough that room reflections and modes are a significant percentage of response the nearfield/farfield transition frequency and distance doesn't matter than much anyway.
Old 18th November 2004, 02:33 PM   #13
But in a home, with a line from floor to ceiling, there are no "limits", the line is infinite.
So in a room, using a ribbon from floor to ceiling, where the floor and ceiling acts as mirrors extending the line there must be other rules than for free field use.´
I´m aware of room contribution for sound sources in all registers.
Guess I´ll have to go read Jim Griffins paper to get the final understanding of linesources.
/Peter
Old 18th November 2004, 04:25 PM   #14
freedom is offline freedom  Denmark
Send a message via MSN to freedom
"A 'true' line source with no farfield doesn't exist; can we agree to limit discussion to real-world circumstance?"
Actually no.
Not in this case since i sought an answer for a theoretical question, an answer to be used in a theoretical paper that is to be judged by theoretical lectors at an university.
If we were to limit the discussion to real world cases - the formula of point-source is far more complex than i´m currently, and probably ever will be, cabable of using or get anything usefull out of.
I´ve read the fundamentals of the point-source in "Loudspeaker and Headphone Handbook" and being a 3rd. semester student (7 more to go) I didn´t understand much of it. And since this project has focus in a completely other and very different subject - this part of the project is a minor detail - and there for the theoretically simplest formula is more than adequate.
So - as i said - cased closed.
However i´m happy to reveal that there are well-informed peoble in this forum. I do though suggest that posts that goes far beyond the question in a thread should go in threads were they do belong :-)
So thanks everyone :-)
Hans-Henning / Denmark
If you cannot measure it - you cannot improve it!
Old 18th November 2004, 04:58 PM   #15
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Freedom,
I really think you need to get your arms around that point source formula if you're are going to be dealing with people at that kind of theoretical level, because I believe that formula applies to a lot of things other than just sound wave dispersion.
Everyone has a photographic memory. It's just that most are out of film.
Old 18th November 2004, 07:54 PM   #16
I´ll do so - if needed. So far it has not been the case - but - as i wrote - there are another 3½ years to come.
So thanks for the advice.
Regs. Hans-Henning
PS I may need an arm-extender in order to get hold of all of it - anywhere you know where i can get this :-) ?
Old 18th November 2004, 08:10 PM   #17
Sorry I can't help you. I don't need to know it, so the only thing in my memory warehouse is the 6db rolloff for point source speakers and 3db for line arrays in the nearfield.
Old 18th November 2004, 08:49 PM   #18
Ron E is offline Ron E  United States
Ron E's Avatar
There is a fairly easy way to get an intuitive feel for the 6dB point source freefield rule. For each doubliing of distance the sound intensity in watts per square meter is reduced by a factor of four.
10 * log (0.25) = -6 (-6.0206...)
The actual formula for sound level is:
dB = 10 * log(Intensity/1e-12) such that 1 watt per square meter is 120dB
If you wish to use pressure rather than intensity you may use:
dB = 20* log (P/0.00002), where P is sound pressure in Pascals.
0.00002 is the sound pressure in pascals defined to be the 0dB level.
Bonus question:
What happens to SPL when the distance goes to zero, assuming dB = 90 at 1 meter
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 83 16th May 2011 12:27 PM
Q formula PeteMcK Multi-Way 10 17th January 2008 07:42 PM
Loudspeaker Filter Formula's Lars Clausen Multi-Way 11 19th November 2003 04:22 AM
Need help on x-over formula Jay Multi-Way 3 12th August 2003 05:28 PM
Anyone have the formula for... Rino odorico Multi-Way 4 22nd January 2003 04:07 PM
Page generated in 0.09787 seconds (79.02% PHP - 20.98% MySQL) with 10 queries
