Is making an XO on a PCB a bad thing?
Old 18th November 2004, 08:29 PM   #11
Gasho is offline Gasho  Croatia
Gasho's Avatar
Point to point hardwiring is the best solution FULLSTOP!
Old 18th November 2004, 08:57 PM   #12
thoriated is offline thoriated  United States
I've developed a point to point method for xovers using small readily available (from McMaster-Carr) brass screw eyes that I'm quite happy with since they can be soldered to and even driven into small drilled pilot holes with an appropriately sized nut driver.
Old 19th November 2004, 12:00 AM   #13
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally posted by peranders
you will get inductive coupling and mutual inductance.
P-A,
I'm going to talk my girlfriend Sonia about this. It needs further investigation.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Is making an XO on a PCB a bad thing?Hide this!Advertise here!
The Second best thing phn Music 11 12th November 2006 10:59 AM
The next big thing? pinkmouse Everything Else 7 15th August 2006 03:24 AM
pre-out vs rec-out ...same thing or not? roger2 Solid State 7 27th July 2006 09:57 PM
next best thing kartsmart Digital Source 5 9th November 2005 10:38 PM
The best thing... Nickolas K. Pass Labs 7 9th July 2003 09:01 PM
