newbee-help with tweeter capacitors - diyAudio
Old 16th November 2004, 06:40 PM   #1
Default newbee-help with tweeter capacitors
sorry but im here on an experimental level. and i did not like the midrange effect that i was getting from my tweeters so i have used different capacitors but i dont like the sound shape i get i used some old capacitors on the same tweeters for some other speekers i built with a wonderful detailed but minimal topend sound but i know so little here as i have just begun that i dont know what the actuall micro-farro tollerence ect. they were.
Please can you help and explain to me what these measurments do and what i should look for if i want a very topend sound with none of that mid treble but without detail loss.I know its more complecated than this but i have to start on an experimental level as i learn.......thankyou
Old 16th November 2004, 06:53 PM   #2
Banned
The first thing you want to do is stop substituting caps if you don't know what you're doing or you stand a good chance of frying your tweeter voice coils. Read a book on DIY loudspeaker building, most will have a section on crossovers, so you know what's safe to do and what is not. Experimentation is a good thing but can be costly if you don't have some training in theory first.
Old 16th November 2004, 08:16 PM   #3
gary f is offline gary f  Canada
gary f's Avatar
What kind/brand/model of tweeter is it??
Capacitors are used to stop the low frequencies from entering the tweeter. The higher the value of the capacitor is, the more you have low frequency passing throught the tweeter.
don't put capacitor with values above 4 or 6 uF in serie with the tweeter or you may damage your unit. general advice.
F
Old 17th November 2004, 01:22 PM   #4
RJ is offline RJ  United States
Maybe the fault is not the tweeter. Woofers have breakup modes around 4000 hz and up.
This woofer starts breaking up at 7000 hz. See first graph;
http://206.13.113.199/ncdiyaudio/mar...comparison.htm
Maybe what you need is an inductor to help flatten the breakup. Example: 1 - 8 ohm tweeter and 1 - 8 ohm woofer to be crossed over at 3000 hz.
Put a 0.42 mh coil in series with the woofer + connection and a 6.6 uF cap in series with the tweeter speaker.
Two sites that will help you with your problem
http://www.audioholics.com/techtips/...rossovers.html
http://www.lalena.com/audio/calculator/xover/
Newbee wants to build Aleph! Thago Pass Labs 7 17th February 2007 08:24 AM
Newbee first project audiophile36 Full Range 4 23rd August 2006 07:14 PM
California Newbee ToE Introductions 1 7th February 2006 04:38 PM
newbee question daveyboy426 Car Audio 7 8th October 2005 07:05 AM
Newbee question: Can this be done (well)? Jennice Multi-Way 18 16th July 2004 03:37 AM
Copyright 1999-2017 diyAudio
