carlosfm said:
Are you serious?
Cold (for us), at day between 10~15º C, but sunshine and clean sky.
Next time bring your speakers.
10°C cold?!
It's 0°C here!
Bricolo said:
10°C cold?!
It's 0°C here!
Really! It's -18°C here at the moment!
Winter is ineluctable.
Eccu said:Really! It's -18°C here at the moment!
18ºC in Finland?
In November?
Are you at the beach?
I'm not sure the tweeter box is also milled.planet10 said:
Well, i doubt there is any output from the tweet inside the box
The irregular thickness of the panels will dramatically change the resonance character of the panels.. it should spread the Q of any such resonances making them harder to excite.
He said "This is milled interier of TL cabinet".
The tweeter has itœ own orginal chamber. The only thig tweeters "box" i for, is crossover and connectors on back. There is no acoustic output from rear side of tweeter. Yes and i forget to mention , all panels of this loudspeaker are 30mm HDF , I milled all needed spaces for big coil in lowpass cection of crossover and for tweeters big magnet/chamber structure.carlosfm said:
As I see it, the tweeter is on a separate box.
And the tweeter is not open-back, of course.
- My Seas based TL beauty
