Old 15th November 2004, 02:55 AM   #1
Default H frame vs W frame dipole woofers
I’m going to build SL’s Phoenix, but am attracted to the all in one design of the Orion. For one thing it'll be easier in a shared room.to move around two boxes rather than four. So I’m thinking of mounting the Phoenix midrange baffle onto the Orion H frame woofer cabinets.
The W frame is wider and lower; the H frame resonance is higher (but with an XO at 120 Hz, both resonances are relatively outside the effective range of the woofers) and by the way the drivers are mounted - the W frame has the benefit of force cancellations.
What do people think of the ‘hybrid’ approach?
Old 15th November 2004, 03:12 AM   #2
That's exactly what I did, so I obviously think it is a good idea.
Steve
Old 15th November 2004, 06:07 AM   #3
The integrated Orion style cabinet couples the strong twin bass driver forces, directly to the mids & tweeters. By SL going this way, this did not *appear*be a problem.
Though the sound of the Orion can now be improved - Revision 0.1 http://www.linkwitzlab.com/orion-rev1.htm - by decoupling the mids from the mid range panel!
So maybe something was lost in integration . .
Old 15th November 2004, 08:46 AM   #4
Default best of both worlds?
Beginning to think that the best all round compromise is to do a woofer ‘box’ Orion - H style, sitting underneath the midrange baffle, but just sitting off it, isolating vibrations.
This would still have the integrated look, and allow experimenting with different-better woofer locations, when "she who likes to be obeyed" is away and/ or I move to a bigger room.
It does mean I'd need a pair of inverted U shaped brackets to support the midrange baffle, straddling the woofer box. Though these could be used as a base, to support midrange driver brackets a la Orion Revision 0.1. This may be a simpler path to further midrange driver isolation than the Phoenix midrange driver spline arrangement, which I hear can be fiddly to construct.
I suspect that Phoenix XO would not require any change, but I still need to confirm or check this??
Old 15th November 2004, 11:26 AM   #5
Equally of course you could do them *W frame Phoenix* style sitting just underneath the midrange baffles, with U shaped brackets to support the midrange baffles.
(Then the Phoenix XO would not require change)
Old 15th November 2004, 04:21 PM   #6
Davey is online now Davey  United States
Rick,
Any kind of a hybrid.....W or H, with Orion or Phoenix style main panels is do-able. There might be some changes required to the crossover system depending upon how you implement it. Generally, a W-baffle would probably require a notch filter and an H-baffle probably wouldn't. The fore/aft position of the mid-panel relative to the bass baffle might also require some time delay.
The force cancellation of the W-frame woofer is desirable if your floor construction/support is marginal. If you're on a slab or some other solid base then I don't believe the H-frame construction would be a problem.
I think isolating the mid-panel from the bass is desirable in all instances.
Davey.
Old 16th November 2004, 03:14 AM   #7
I have my main panel and H-frame box constructed as separate units to decouple them somewhat. The main unit normally fits over the bass, but you can see how they work here:
There is a cross brace at the back of the main unit for stability.
Steve
Old 16th November 2004, 03:20 AM   #8
Good thinking Steve.
What do think of John K’s claims for higher output in the NaO U frame?
Old 16th November 2004, 10:55 AM   #9
I suspect he's right. I tried mine as a U-baffle and an H-baffle and I did get he impression that the U had more output.
Steve
Old 16th November 2004, 10:55 PM   #10
Though was there more room interaction with the U Frame?
W-frame Dipole Construction Q weinstro Multi-Way 9 20th August 2007 04:31 PM
how to calculate resonance in dipole H-frame? thadman Subwoofers 4 17th April 2007 09:10 PM
W-Frame or H-Frame dipoles? performace issues? JinMTVT Subwoofers 34 5th October 2006 05:44 PM
any compromises in using Linkwitz W-frame dipole? taloyd Subwoofers 9 6th July 2006 10:57 PM
H frame/ Dipole/U frame ???????? j.burtt Multi-Way 24 1st May 2006 04:50 AM
Page generated in 0.09703 seconds (80.86% PHP - 19.14% MySQL) with 10 queries
