Old 12th November 2004, 04:26 AM   #1
Default making a MMTTMM version of an MTM design
Is it easy to modify the crossover of a MTM design to suit a MMTTMM version of it.
Old 12th November 2004, 07:19 AM   #2
foo is offline foo  Tibet
i think it's easier to build MTTM ones
Old 12th November 2004, 07:41 AM   #3
Send a message via AIM to joe carrow
As I understand it, the hard part with converting an MTM design to MMTTMM would be the trouble you will have with interferance between the drivers. Higher frequencies require that the drivers are closer together- within a certain fraction of a wavelength of that frequency. Having two tweeters could give you trouble- and if the crossover is high enough, the two groups of mids could be too far apart.
The MMTTMM starts to look like a line array- I'd suggest reading about line arrays, comb filtering, and that sort of thing. I haven't had trouble with this kind of thing before- it seems to be the one area in speaker design that I've actually paid attention to
IMO, the best bet here would be to get a more efficient tweeter to match the improved sensitivity due to doubling the number of woofers, and then google for something like a crossover calculator
Good luck with your project.
Old 12th November 2004, 08:09 AM   #4
If you want to double speakers in existing design, answer is NO. If you want to design your own, imho there is no reason to do it because of wasting money and really difficult problems to solve.
Meer MTM
Old 12th November 2004, 01:15 PM   #5
RJ is offline RJ  United States
Why two tweeters???
The center to center spacing can't be achieved with 99% of the tweeters out there. With 4 M's the sensitivity would go up from 4 to 6 db. Just match one tweeter at that sensitivity.
Read Jim Griffins white paper on line arrays . It'll explain the problems of speaker size and placement and sensitivity gained by more woof's;
http://www.audiodiycentral.com/awpapers.shtml
Also Bottlehead has built quite a few MMMMT's;
http://www.bottlehead.com/valve/wham...les/page2.html
If you model your design on Baffle Diffraction Simulator you'll visually will see the problem of sound cancellation and re-enforcement;
http://www.pvconsultants.com/audio/d...ownloadbds.htm
Old 12th November 2004, 01:40 PM   #6
BAM is offline BAM
Send a message via AIM to BAM
There are some designs out there that use two vertically-arrayed tweeters, and the result is vertical dispersion control. Not all that important, and kind of a novelty, but that's what it does.
Old 29th July 2008, 06:24 AM   #7
I'm curious, why not a WMTMW setup; in other words, a 3-way system? That is actually quite common and you should be able to find design and modeling discussion about this.
I believe there might be a long discussion here somewhere covering the entire design and modeling up to the final design for a Dayton Reference WMTMW system.
Just a thought.
Steve/bluewizard
Old 29th July 2008, 07:35 AM   #8
Also a 0.5MMTM0.5M should work well (2.5 way MTM). Have not seen such a design sofar though, 3 way seems more common.
I don't believe in audio believings.
Old 29th July 2008, 08:19 AM   #9
Hi.
I was thinking of twin tweeters also, I have read that there are problems involved, but some hi end designs do use multi tweeters and I have not found a 94 to 96 db at 1w/1m tweeter at all, let alone at the cost of two Vifa D26NC55 ($29 each).
If there are please tell.
Thanks.
Old 29th July 2008, 12:21 PM   #10
Default Re: making a MMTTMM version of an MTM design
The short answer is yes it is easy, but you will get a lot more lobing.
You change the MTM components to suit double or half impedance.
/sreten.
Career is acoustics and enclosure making and amplifiers and speaker design Amit_112dB Introductions 3 3rd September 2007 05:00 AM
What is the version of 45 cd149dc Tubes / Valves 3 19th June 2007 11:59 AM
Zen Version 4 R10 skidave Pass Labs 1 8th March 2007 06:52 PM
Zen Version 4 skidave Pass Labs 1 19th December 2006 06:36 AM
how would i go about making a new passive preamp design Diederick Solid State 8 3rd December 2001 12:46 AM
Page generated in 0.10859 seconds (79.40% PHP - 20.60% MySQL) with 10 queries
