Old 12th November 2004, 03:59 AM   #1
Question Possible to build good speakers with the following?
Hi there,
This is my first post and I'm sure I'll get flamed for the general nature of it, but I'm looking for help in an area that I have absolutely NO expertise. ...yet!
I have the opportunity to buy the following from a friend:
-6 X 4 Ohm, 6.5" JBL mids that came from JBL Control 5 monitor speakers
-6 X 8 Ohm, 1" JBL tweeters that came from the same speaker
-2 X ? Ohm, 8" JBL subs that came from somewhere
The problem is that we know very little about the original speaker combo other than:
Response of 50 Hz to 20 kHz, 175W max, X-over @ 3 kHz, Effective box volume is ~1,500 cu inches (1,200 total box volume, minus speaker volume, minus the volume of all the other stuff that's presumably in there, plus a 25% gain in volume perceived by the speaker through foam insulation).
The 8" is a complete unkown, although I'm guessing they are 4 Ohm due to their beefy nature and "automotive" look.
My question are:
-does anyone think it's feasible to build a quality set of front speakers with what I've got here? I've got a Yamaha HTR-5490 that puts out 100W RMS and is stable at 4 Ohms in the front channels only if the others have at least 6 Ohm impedence.
-would it be possible to build a decent crossover for these speakers knowing what I know?
HELP ! ! !
Old 12th November 2004, 07:31 AM   #2
Default Mmmm - lots...
Take mids use one from 80 up to 3kHz, X-O to tweet. Take other two use in parallel from 80Hz to whenever the FR of single drops down on its own - probably 200Hz. use one 8 inch below 80 Hz... from 80 - 20kHz - put in one sealed box, and 8 inch in own sealed / vented box - depending on Thiele Small specs...
or use two mids and a tweeter for a left, right and centre channel
That said - difficult to judge outcome or applicability of solution without TS specs... or for that matter design the thing...
BTW if you don't have TS param.s go elsewhere, if you want good sound... they'd have to be dirt cheap to make it worth it otherwise
JBL web-site, might have some info...
Here is site with cool links and software to see if it will work... A book like Martin Colloms hi performance speaker design or Laurence Dickason ? Loudspeaker Design Cookbook is good idea...
http://www.speakerbuilding.com/
Old 12th November 2004, 10:13 AM   #3
DirkD is offline DirkD  South Africa
Unless you have the T.S. parameters you have no way of building even remotely good speakers with the parts you have.
D
Old 12th November 2004, 10:16 AM   #4
Default more from SA
Hi, glad to see there's a few blokes from RSA... - mostly the Cape...
Now back to topic...
TDA 1311A Is it good to build a DAC with? Van Hai Digital Source 0 11th October 2004 04:36 PM
Is this a good sub to build? AudioIsFun Subwoofers 8 9th January 2004 08:13 PM
Looking to build cheap, efficient, good sounding floorstanding speakers - the results tool49 Multi-Way 4 26th December 2003 08:43 PM
Looking to build cheap, efficient, good sounding floorstanding speakers tool49 Multi-Way 80 21st November 2003 03:04 AM
What's a good, basic pre-amp to build Rino odorico Everything Else 0 18th February 2003 02:05 PM
Page generated in 0.08527 seconds (71.59% PHP - 28.41% MySQL) with 10 queries
