Hi, I'm new here...
Heres a starter question... I wanna design a passive stereo three speaker cabinet. (1)LEFT(full range) / (2)SUB / (3)RIGHT(full range) -(it's a baritone guitar rig) I have a stereo tube power-amp to power it... What do I need to be able to run the two 1/4inch Left/Right outputs of the amp into Speaker 1&3 and also filter low frequencies to the SUB speaker (2) ? Is a way to do this? Is there a part on the market that has two 1/4inch inputs that can be built into the cabinet and then wired to the three speakers....(with or without a selectable frequency knob...) thanks DIY-ers great forum |
#2 |
#3 |
That's definitely NOT what he needs.
If you have a dual voice coil woofer then it's doable with a pair of passive crossovers. You'll have to add the 1/4" jacks though. If your sub is not dual voice coil you're out of luck unless you get another sub. |
#4 |
You're right Bill - I missed the word "passive" in the original post.
Paul |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| Can Zaphs notch filter be used without the BSC filter? | GuyPanico | Full Range | 0 | 21st July 2007 01:27 AM |
| Just one big filter cap or more smaller filter caps ... | beppe61 | Power Supplies | 2 | 18th July 2006 05:46 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| chassis-mounted filter or IEC plug filter | jarthel | Solid State | 7 | 11th March 2002 10:17 AM |
| Page generated in 0.07696 seconds (69.02% PHP - 30.98% MySQL) with 10 queries |
